[gdal-dev] Transforming Raster Points from GeoTIFF with GCPs
Matt.Wilkie at yukon.ca
Fri Dec 10 12:45:24 PST 2021
and https://gdal.org/programs/gdaltransform.html
-Matt
From: gdal-dev <gdal-dev-bounces at lists.osgeo.org> On Behalf Of Simon Eves
Sent: December 10, 2021 12:21 PM
To: Yann-Sebastien Tremblay-Johnston <yanns.tremblay at gmail.com>
Cc: gdal dev <gdal-dev at lists.osgeo.org>
Subject: Re: [gdal-dev] Transforming Raster Points from GeoTIFF with GCPs
*** External email: Do not click on links or attachments except from trusted senders. ***
Aha! That's the bit I hadn't found. Thank you! :)
On Fri, Dec 10, 2021 at 10:38 AM Yann-Sebastien Tremblay-Johnston <yanns.tremblay at gmail.com<mailto:yanns.tremblay at gmail.com>> wrote:
Simon,
See the Transformer API, in particular https://gdal.org/api/gdal_alg.html?highlight=transformer#_CPPv419GDALTransformerFunc (or gdal.Transformer in Python).
Sebastien
On Fri, Dec 10, 2021 at 10:24 AM Simon Eves <simon.eves at omnisci.com<mailto:simon.eves at omnisci.com>> wrote:
So we have a GeoTiFF of Sentinel-1 imagery which `gdalinfo` reports as having a GCP projection with 210 points, which we'd (perhaps naively?!) like to import directly, transforming to WGS84 on the fly.
Obviously a simple OGRSpatialReference/OGRCoordinateTransformation transform isn't going to do anything, so I assume we have to do the GCP transform manually.
I found the GCPCoordinateTransformation class and other supporting code in ogr2ogr_lib.cpp as used by gdaltransform, which seems to do what we need, but of course it's not in the core GDAL library so we can't "just use it".
Before embarking on lifting out that code to implement an on-the-fly transformer in our system, I just wanted to make sure I wasn't missing any functionality elsewhere that would make it easier.
It may also be more efficient to just kick off a gdalwarp to pre-convert the file so we can just import it with no transformation required, but that seems ugly unless it's gonna be WAY more efficient?
Thanks,
Simon
[http://www2.omnisci.com/l/298412/2018-09-18/3sqpg/298412/61753/OmniSci_Email_Header2.png]<http://www.omnisci.com/>
Simon Eves
Senior Graphics Engineer, Rendering Group
100 Montgomery St (5th Floor), San Francisco, CA 94104, USA
Email: simon.eves at omnisci.com<mailto:simon.eves at omnisci.com> | Cell:
+1 (415) 902-1996
gdal-dev mailing list
gdal-dev at lists.osgeo.org<mailto:gdal-dev at lists.osgeo.org>
https://lists.osgeo.org/mailman/listinfo/gdal-dev
Simon Eves
+1 (415) 902-1996
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20211210/4471258a/attachment-0001.html>
