[gdal-dev] Problem reading Sentinel-1 GeoTIFFs
Even Rouault
even.rouault at spatialys.com
Fri Dec 10 15:40:52 PST 2021
Those files use a invalid GeogEllipsoidGeoKey=4326 for the WGS 84
ellipsoid. The correct code should be 7030. Sometimes should report that
to the data producer.
Warning silenced in https://github.com/OSGeo/gdal/pull/4975
Le 11/12/2021 à 00:05, Simon Eves a écrit :
> After also finding this thread...
> https://github.com/OSGeo/gdal/issues/2321
> <https://github.com/OSGeo/gdal/issues/2321>
> ...I installed geotiff-bin and ran listgeo on the file.
> It also spits the same message (three times).
> The output is attached.
> S
> On Fri, Dec 10, 2021 at 2:56 PM Simon Eves <simon.eves at omnisci.com
> <mailto:simon.eves at omnisci.com>> wrote:
> Further to my earlier post about GCP Transforms, I now have that
> code written, and it seems to be functioning fine, although
> whether it's generating the right values is as yet unclear.
> The problem is that I am having trouble creating the secondary
> transformation from whatever the output space of the GCP transform
> is, to my desired space (4326 in this case).
> Whenever I call GetGCPSpatialRef() on the datasource, I get the
> following error (twice)
> PROJ: proj_create_from_database: ellipsoid not found (1)
> I get the same error (also twice) when I run gdalinfo on the file,
> but then with a plausible looking SR dump, which may of course
> just be a default:
> ______________________________________________________
> $ gdalinfo
> s1b-iw-grd-vv-20211110t033513-20211110t033538-029520-0385e8-001.tiff
> ERROR 1: PROJ: proj_create_from_database: ellipsoid not found
> Driver: GTiff/GeoTIFF
> Files:
> Size is 25541, 16650
> GCP Projection =
> GEOGCRS["WGS 84",
> DATUM["World Geodetic System 1984",
> ELLIPSOID["unnamed",6378137,298.25722356049,
> LENGTHUNIT["metre",1]]],
> PRIMEM["Greenwich",0,
> ANGLEUNIT["degree",0.0174532925199433]],
> CS[ellipsoidal,2],
> AXIS["geodetic latitude (Lat)",north,
> ORDER[1],
> AXIS["geodetic longitude (Lon)",east,
> ORDER[2],
> ID["EPSG",4326]]
> Data axis to CRS axis mapping: 2,1
> GCP[ 0]: Id=1, Info=
> (0,0) ->
> (45.0323375081341,62.6475859336067,149.992539359257)
> [etc.]
> My constructed OGRCoordinateTransformation for the second
> transform is therefore a no-op, but the final values (which are
> therefore just the values out of the GCP transform) are definitely
> not 4326.
> omnisql> select * from s1 where rowid<10;
> raster_lon|raster_lat
> 476788.1263799404|747980.9704571336
> 460813.8583986053|747120.1413700345
> 444852.7791957706|746184.4282221086
> 428904.8887714364|745173.8310133558
> 412970.1871256025|744088.349743776
> 397048.6742582691|742927.9844133693
> 381140.3501694361|741692.7350221358
> 365245.2148591036|740382.6015700753
> 349363.2683272713|738997.5840571877
> 333494.5105739397|737537.6824834733
> Those are the first ten pixels of the first scanline of the (~25K
> x ~16K) file, btw, so intuitively there is something worrying me
> about those values anyway (they are moving very quickly and
> non-linearly considering that's just ten pixels).
> Anyway, some Googling led me to...
> https://gitlab.orfeo-toolbox.org/s1-tiling/s1tiling/-/issues/46
> <https://gitlab.orfeo-toolbox.org/s1-tiling/s1tiling/-/issues/46>
> ...which seems very related, and even mentions a patch to
> libGeoTIFF by Even. I checked, and that patch IS in the (internal,
> as configured in the build) GeoTIFF in our GDAL.
> This is with GDAL 3.4.0 and Proj 7.2.1.
> Thanks in advance,
> Simon
> <http://www.omnisci.com/>
> Simon Eves
> Senior Graphics Engineer, Rendering Group
> 100 Montgomery St (5th Floor), San Francisco, CA 94104, USA
> Email: simon.eves at omnisci.com <mailto:simon.eves at omnisci.com> |
> Cell: +1 (415) 902-1996
> Simon Eves
> Email: simon.eves at omnisci.com <mailto:simon.eves at omnisci.com> | Cell:
> +1 (415) 902-1996
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20211211/c1934591/attachment-0001.html>
