[gdal-dev] GDAL COG random fringe on zoom levels
Even Rouault
even.rouault at spatialys.com
Fri Dec 17 15:20:45 PST 2021
Pasted into https://github.com/OSGeo/gdal/issues/5016
Le 17/12/2021 à 23:25, Craig Bruce a écrit :
> I tried to submit this issue on GitHub, but it wouldn't let me press
> the Submit button and wouldn't tell me why not.
> ## Expected behavior and actual behavior.
> The generation of Cloud-Optimized GeoTIFF images sometimes includes an
> fringe of random colors around the edge of opaque and transparent
> pixels of the coarser zoom levels.
> The edge of a COG level with an alpha channel should be a smooth
> tapering of translucent pixels with the proper colors from the source
> image.
> ## Steps to reproduce the problem.
> Using GDAL-3.3.1, take an image [like this,
> naip_denull.tif](https://drive.google.com/file/d/1KIJ-8E3nxxaVCdQ1uaKE4rcZtCtlqT0x/view?usp=sharing)
> (188 MB) and run:
> $ gdal_translate naip_denull.tif cog.tif -of COG -co COMPRESS=LZW
> Then open the COG in an application like GIMP that lets you select
> which zoom-level to view. Choose the coarsest level and view — random
> fringe!
> Screenshot:
> All of the reduced-resolution levels have this problem to a degree,
> though the more zoomed-out ones have it worse. Using these levels to
> produce a map makes it look bad.
> The problem seems to be exacerbated by the source image having pixels
> that are either fully opaque or fully transparent and by the image
> content having complicated patterns, such as streets.
> My guess is that the resampling method when generating a zoomed-out
> pixel is indiscriminately including source-pixel values that are fully
> transparent and shouldn't be included. The randomness of the fringe
> suggests that the sample values for transparent pixels remain
> uninitialized as some kind of optimization.
> I've seen this problem before on other systems with a dark fringe from
> erroneously including transparent pixels that have sample values of 0.
> ## Operating system
> Fedora 33 Linux, x64.
> ## GDAL version and provenance
> GDAL-3.3.1.
> Dr. Craig S. Bruce
> Senior Software Developer
> CubeWerx//Inc.
> https://www.cubewerx.com <http://www.cubewerx.com/>
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20211218/92cf39d4/attachment.html>
