[gdal-dev] libgdal.so: undefined reference to `qh_qh'
Pei JIA
jp4work at gmail.com
Wed Dec 22 02:38:18 PST 2021
Hi, all:
Again, I failed to build *gdal-3.4.0* , against the current *qhull 8.1.1 *.
1. I used
*CFLAGS="-O3 -pipe -march=native -w"; CXXFLAGS="${CFLAGS}" ./configure
--with-proj=$ROOTDIR --with-cpp14 --with-crypto=yes --with-liblzma
--with-python --with-geos=$ROOTDIR --with-spatialite --with-openjpeg
--with-hdf5=$ROOTDIR --with-netcdf=$ROOTDIR --with-pg --with-curl
--with-png --with-qhull=yes*
for configuration.
2. while making, I got the following error messages:
*echo 'CONFIG_FORMATS="derived gtiff hfa mem vrt aaigrid adrg aigrid
airsar arg blx bmp bsb cals ceos ceos2 coasp cosar ctg dimap dted elas
envisat ers esric fit gff gsg gxf hf2 idrisi ilwis ingr iris iso8211
jaxapalsar jdem kmlsuperoverlay l1b leveller map mrf msgn ngsgeoid nitf
northwood pds prf r raw rmf rs2 safe saga sdts sentinel2 sgi sigdem srtmhgt
stacit stacta terragen tga til tsx usgsdem xpm xyz zarr zmap rik ozi eeda
plmosaic rda wcs wms wmts daas ogcapi rasterlite mbtiles grib pdf heif exr
webp openjpeg netcdf hdf5 gif png pcraster fits jpeg pcidsk postgisraster
jpegls"' >> gdal-config-inst*
jpegls"' >> gdal-config*
*cat gdal-config.in <http://gdal-config.in> >> gdal-config*
*cat gdal-config.in <http://gdal-config.in> >> gdal-config-inst*
*chmod a+x gdal-config*
*chmod a+x gdal-config-inst*
*/bin/bash ....../gdal/libtool --mode=link --silent g++ gdal_create.lo
....../gdal/libgdal.la <http://libgdal.la> -o gdal_create*
*/bin/bash ....../gdal/libtool --mode=link --silent g++ gdal_contour.lo
....../gdal/libgdal.la <http://libgdal.la> -o gdal_contour*
*/usr/bin/ld: ....../gdal/.libs/libgdal.so: undefined reference to `qh_qh'*
*/usr/bin/ld: ....../gdal/.libs/libgdal.so/usr/bin/ld
<http://libgdal.so/usr/bin/ld>: undefined reference to `:
....../gdal/.libs/libgdal.so: undefined reference to `qh_qhqh_qh'*
*collect2: error: ld returned 1 exit status*
*make[1]: *** [GNUmakefile:89: gdalinfo] Error 1*
*make[1]: *** Waiting for unfinished jobs....*
*make[1]: *** [GNUmakefile:110: nearblack] Error 1*
*make[1]: *** [GNUmakefile:92: gdalmdiminfo] Error 1*
*make[1]: *** [GNUmakefile:95: gdalmdimtranslate] Error 1*
*make[1]: *** [GNUmakefile:134: gdaldem] Error 1*
*make[1]: *** [GNUmakefile:149: gdalsrsinfo] Error 1*
*make[1]: *** [GNUmakefile:191: gdal_viewshed] Error 1*
*make[1]: *** [GNUmakefile:143: gdaltransform] Error 1*
*make[1]: *** [GNUmakefile:98: gdal_translate] Error 1*
*make[1]: *** [GNUmakefile:113: gdalmanage] Error 1*
*make[1]: *** [GNUmakefile:101: gdaladdo] Error 1*
*make[1]: *** [GNUmakefile:146: gdallocationinfo] Error 1*
*make[1]: *** [GNUmakefile:107: gdal_contour] Error 1*
*make[1]: *** [GNUmakefile:104: gdalwarp] Error 1*
*make[1]: *** [GNUmakefile:131: gdalenhance] Error 1*
*make[1]: *** [GNUmakefile:194: gdal_create] Error 1*
*make[1]: Leaving directory '....../gdal/apps'*
*make: *** [GNUmakefile:123: apps-target] Error 2*
Did anybody successfully build *gdal-3.4.0* with *qhull-8.1.1* ? Please
give me a hand... Thank you ...
Pei JIA, Ph.D.
Email: jp4work at gmail.com
Welcome to Vision Open
http://www.visionopen.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20211222/2d0c717e/attachment.html>
