[gdal-dev] Fw: Building GDAL with ECW support
Jeff McKenna jmckenna at gatewaygeomatics.com
Mon Feb 1 11:24:40 PST 2021
Hi Kevin,
Some quick thoughts for your case:
- you can paste your large commands and code at https://pastebin.com/
and then share that link with this mailing list discussion in your
message (for images, similar with https://pasteboard.co/ )
- the best source of build help is the GDAL "BuildHints" page
(https://trac.osgeo.org/gdal/wiki/BuildHints) and specifically for ECW:
https://trac.osgeo.org/gdal/wiki/ECW Although the hints can be old and
for various versions, I find following those pages a "gold mine" of
information.
-jeff
Jeff McKenna
GatewayGeo: MapServer Consulting and Training Services
co-founder of FOSS4G
http://gatewaygeo.com/
On 2021-02-01 3:11 p.m., Pteroglossus via gdal-dev wrote:
> Dear list,
> I'm not a developer, I would just like to use the maps I have on Linux
> and stay away from Windows.
> I've been trying to import some raster maps into GRASS. Problem is, they
> are .ecw files.
> If I understood well, GDAL does not support this format natively and has
> to be built including specific modules to allow working with these files.
> I tried following the instructions here and everything went fine until
> the "make" instruction which gives an endless loop.
> I could provide you with the output of the "make" command but the
> resulting file is over 100 Kb.
> Could you point me in the right direction please?
> Thanks,
> Kevin
