[gdal-dev] Fw: Building GDAL with ECW support
    pteroglossus at pm.me
    Mon Feb  1 11:11:31 PST 2021
Dear list,
I'm not a developer, I would just like to use the maps I have on Linux and stay away from Windows.
I've been trying to import some raster maps into GRASS. Problem is, they are .ecw files.
If I understood well, GDAL does not support this format natively and has to be built including specific modules to allow working with these files.
I tried following the instructions here and everything went fine until the "make" instruction which gives an endless loop.
I could provide you with the output of the "make" command but the resulting file is over 100 Kb.
Could you point me in the right direction please?
Thanks,
Kevin
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20210201/e4a744b8/attachment.html>
