[gdal-dev] Fw: Building GDAL with ECW support
pteroglossus at pm.me
Mon Feb 1 12:21:28 PST 2021
Hi Jeff, Richard,
Thanks for your quick replies.
I did come across this page:"https://trac.osgeo.org/gdal/wiki/ECW" but as you said, the info is outdated and therefore confusing when you don't really know what you're doing...
The instructions here (https://gist.githubusercontent.com/aborruso/eed6895278edd320db6631b33d10836e/raw/53e1bd297625804a2120ba341ae6ae3e6023a6f8/gdal_ecw.sh) seemed similar but clearer and I was able to complete most of the steps, including these two:
- "/.configure" : https://pastebin.com/UGsKP7ts
- "make clean": https://pastebin.com/M8P87CVq
My problem started there at the last step:
- "make": https://pastebin.com/6bMjhcyk
I have the feeling it might be fixable with some knowledge of the building process, which I suspect you may have.
If I messed up too badly, I'll delete everything and start over using Richard's notes.
Regards,
Kevin
‐‐‐‐‐‐‐ Original Message ‐‐‐‐‐‐‐
On Monday, February 1, 2021 4:24 PM, Jeff McKenna <jmckenna at gatewaygeomatics.com> wrote:
> Hi Kevin,
> Some quick thoughts for your case:
> - you can paste your large commands and code at https://pastebin.com/
> and then share that link with this mailing list discussion in your
> message (for images, similar with https://pasteboard.co/ )
> - the best source of build help is the GDAL "BuildHints" page
> (https://trac.osgeo.org/gdal/wiki/BuildHints) and specifically for ECW:
> https://trac.osgeo.org/gdal/wiki/ECW Although the hints can be old and
> for various versions, I find following those pages a "gold mine" of
> information.
> -jeff
> Jeff McKenna
> GatewayGeo: MapServer Consulting and Training Services
> co-founder of FOSS4G
> http://gatewaygeo.com/
> On 2021-02-01 3:11 p.m., Pteroglossus via gdal-dev wrote:
> > Dear list,
> > I'm not a developer, I would just like to use the maps I have on Linux
> > and stay away from Windows.
> > I've been trying to import some raster maps into GRASS. Problem is, they
> > are .ecw files.
> > If I understood well, GDAL does not support this format natively and has
> > to be built including specific modules to allow working with these files.
> > I tried following the instructions here and everything went fine until
> > the "make" instruction which gives an endless loop.
> > I could provide you with the output of the "make" command but the
> > resulting file is over 100 Kb.
> > Could you point me in the right direction please?
> > Thanks,
> > Kevin
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
