[gdal-dev] Fw: Building GDAL with ECW support
Richard Duivenvoorde rdmailings at duif.net
Wed Feb 3 01:28:26 PST 2021
On 2/3/21 2:20 AM, Pteroglossus via gdal-dev wrote:
> I did my best to thoroughly follow Richard's notes using the 5.5.0 ECW SDK and gdal 3.1.4... No luck, the "configure" command now fails halfway it seems, although it did work for my first try:
> https://pastebin.com/rSZfPRS0
Looks like you are missing a recent libproj and/or libproj-dev or so...
You are almost there, after the configure it is just 'make install' :-)
Working with the docker image, is also a good alternative! But... you have to make yourself a little familiar with Docker then...
Regards,
Richard
