[gdal-dev] Fw: Building GDAL with ECW support
pteroglossus at pm.me
Tue Feb 2 17:20:04 PST 2021
I did my best to thoroughly follow Richard's notes using the 5.5.0 ECW SDK and gdal 3.1.4... No luck, the "configure" command now fails halfway it seems, although it did work for my first try:
https://pastebin.com/rSZfPRS0
As much as I would like to take on the challenge of compiling GDAL with ECW, I'm in way over my head here! I think I'm gonna go for the conversion to GeoTiff as suggested.
Thanks a lot for your help!
Regards,
Kevin
‐‐‐‐‐‐‐ Original Message ‐‐‐‐‐‐‐
On Tuesday, February 2, 2021 5:35 AM, Richard Duivenvoorde <rdmailings at duif.net> wrote:
> On 2/1/21 9:21 PM, Pteroglossus via gdal-dev wrote:
> > My problem started there at the last step:
> > - "make": https://pastebin.com/6bMjhcyk
> Not sure which ecw sdk you downloaded, but when I did the notes there told me to use GDAL 3.1, and from your output you are using 2.3.1?
> From the ERDAS_ECW_JPEG2000_SDK.pdf:
> Version 5.5 Update 2
> Released: September 2020
> Updated public GDAL driver to be compatible with 5.5 release and GDAL 3.1.
> Not sure if it should compile with 2.3.1 also but because of that I just 'git cloned' the gdal repo and then 'git checkout release/3.1' to get to the 3.1 sources...
> Good luck
> Regards,
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
