[gdal-dev] Fwd: ogr2ogr crash attempting to drop table in filegdb
jratike80 jukka.rahkonen at maanmittauslaitos.fi
Fri Feb 5 02:43:34 PST 2021
SQL in ogr2ogr is only for SELECT. For any other purpose use ogrinfo.
An example:
ogrinfo -sql "alter table point_p rename column test to foo" point.gpkg
-dialect sqlite
-Jukka Rahkonen-
janhec wrote
> Dear list,
> About the filegdb driver
> Attempting:
> ogr2ogr -f FILEGDB test.gdb bag2101.gdb -update -sql "drop table
> standplaats"
> crashed ogr2ogr (obtained from gisinternals.com,
> gdal-302-1928-x64-core.msi
> etc) with a heap corruption. (VS: Unhandled exception at
> 0x00007FFE1C6EF099
> (ntdll.dll) in ogr2ogr.exe: 0xC0000374: A heap has been corrupted
> (parameters: 0x00007FFE1C7587F0).)
> The table does get dropped.
> The table was inserted from a shapefile using:
> ogr2ogr --config shape_encoding "UTF-8" --config FGDB_BULK_LOAD YES
> -append
> -f "filegdb" bag2101.gdb sta.shp -nln standplaats -sql "select identifica
> as identificatie,hfdadresid as hoofdadresid,* from sta", and displays
> properly in Qgis.
> So the filegdb driver appears to be properly installed.
> Also,  I could not get column renaming to work. Using dialects filegdb and
> OGR SQL,
> ogr2ogr -f FILEGDB test.gdb test.gdb -update -sql "alter table vbo_actueel
> rename column oppervlakt to oppervlakte"  -dialect "FILEGDB"
> gives ERROR 1: Failed at executing 'alter table vbo_actueel rename column
> oppervlakt to oppervlakte' (An invalid SQL statement was used.);
> using -dialect SQLITE, I get
> ERROR 1: In ExecuteSQL(): sqlite3_prepare_v2(Alter table vbo_actueel
> rename
> column oppervlakt to oppervlakte): no such table: vbo_actueel
> whereas ogrinfo clearly states the table exists.
> I am trying to clear my arcgis ties preferring Qgis and for reasons of
> cost, but sometimes I do need to provide data in filegdb format.
> Thanks in advance for any advice,
> Jan
> PS. I do not add the shapefile for reference, since that version of this
> mail got "rejected by the owner" for being about 1500 bytes in size.
> gdal-dev mailing list
> gdal-dev at .osgeo
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
Sent from: http://osgeo-org.1560.x6.nabble.com/GDAL-Dev-f3742093.html
