[gdal-dev] Gdal install from source error : undefined reference to `opj_encoder_set_extra_options'
Sylvain Maffren smaffren at gmail.com
Mon Feb 8 00:52:46 PST 2021
I answer to myself (I just realized that my email topic wasn't good).
Sylvain--
Le lundi 08 février 2021 à 08:53 +0300, Sylvain Maffren a écrit :
> Hello,
> I am trying to insatll GDAL manually by compiling from src. Here is
> the different versions of the librairies used :
> GDAL_VERSION=3.2.1GEOS_VERSION=3.8.1 (manual
> compilation)PROJ_VERSION=7.2.1 (manual
> compilation)HDF5_VERSION=1.10.5 (manual
> compilation)NETCDF_VERSION=4.7.4 (manual
> compilation)OPENJPEG_VERSION=2.4.0 (manual
> compilation)PROJ_DAT_VERSION=1.8 (manual compilation)
> I had some errors I managed to fix by following some google posts. It
> just remains one and I can't find any clue on internet on how to fix
> it.
> Here is the way I used to compile GDAL from src :
> cd $ROOTDIR/srcecho "Downloading sources and compiling GDAL"wget -q
> https://github.com/OSGeo/gdal/releases/download/v${GDAL_VERSION}/gdal-${GDAL_VERSION}.tar.gztar
> -xvf gdal-${GDAL_VERSION}.tar.gz &>> /dev/null
> cd $ROOTDIR/src/gdal-${GDAL_VERSION}CFLAGS="-O3 -pipe -march=native
> -w"; CXXFLAGS="${CFLAGS}" ./configure --with-proj=$ROOTDIR --with-
> cpp14  --with-crypto=yes --with-liblzma --with-python --with-
> geos=$ROOTDIR --with-spatialite --with-openjpeg=$ROOTDIR --with-
> hdf5=$ROOTDIR --with-netcdf=$ROOTDIR --with-pg --with-curl --with-
> png make -s -j$(nproc) &>> /dev/null make installldconfig make clean
> &>> /dev/null
> echo "Install GDAL python"    cd $ROOTDIR/src/gdal-
> ${GDAL_VERSION}/swig/pythonpython3 setup.py build && python3 setup.py
> install
> I got this error and I am unable to complete the compilation :
> make[1] : on entre dans le répertoire « /usr/src/gdal-
> 3.2.1/apps »/bin/bash /usr/src/gdal-3.2.1/libtool --mode=link --
> silent g++  gdalinfo_bin.lo  /usr/src/gdal-3.2.1/libgdal.la  -o
> gdalinfo/usr/bin/ld: /usr/src/gdal-3.2.1/.libs/libgdal.so: undefined
> reference to `opj_encoder_set_extra_options'collect2: error: ld
> returned 1 exit statusmake[1]: *** [GNUmakefile:90: gdalinfo] Error
> 1make[1] : on quitte le répertoire « /usr/src/gdal-3.2.1/apps »make:
> *** [GNUmakefile:120: apps-target] Error 2
> It seems that the reference to  `opj_encoder_set_extra_options' is
> linked to the OpenJPEG librairy but I didn't have any errors when I
> compiled manually OpenJPEG librairy. And I didn't find any clue on
> internet to fix it.
> Did I miss something in my compilation process ?
> Thanks in adavance for your advice.
> Sylvain
Sylvain
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20210208/dc384f3f/attachment.html>
