[gdal-dev] Gdal install from source error : undefined reference to `opj_encoder_set_extra_options'
Sylvain Maffren
smaffren at gmail.com
Tue Feb 9 00:00:26 PST 2021
I found the answer. I had an old installation of OpenJPEG lib (2.3.1)
on Gdal was still pointing on it (but this version doesn't
contain opj_encoder_set_extra_options). After a clean removal and fresh
re-compiling of OpenJPEG 2.4.0 I managed to compile GDAL.
Thanks.
Sylvain.
Le lundi 08 février 2021 à 11:52 +0300, Sylvain Maffren a écrit :
> I answer to myself (I just realized that my email topic wasn't good).
> Sylvain--
> Le lundi 08 février 2021 à 08:53 +0300, Sylvain Maffren a écrit :
> > Hello,
> > I am trying to insatll GDAL manually by compiling from src. Here is
> > the different versions of the librairies used :
> > GDAL_VERSION=3.2.1GEOS_VERSION=3.8.1 (manual
> > compilation)PROJ_VERSION=7.2.1 (manual
> > compilation)HDF5_VERSION=1.10.5 (manual
> > compilation)NETCDF_VERSION=4.7.4 (manual
> > compilation)OPENJPEG_VERSION=2.4.0 (manual
> > compilation)PROJ_DAT_VERSION=1.8 (manual compilation)
> > I had some errors I managed to fix by following some google posts.
> > It just remains one and I can't find any clue on internet on how to
> > fix it.
> > Here is the way I used to compile GDAL from src :
> > cd $ROOTDIR/srcecho "Downloading sources and compiling GDAL"wget -q
> > https://github.com/OSGeo/gdal/releases/download/v${GDAL_VERSION}/gd
> > al-${GDAL_VERSION}.tar.gztar -xvf gdal-${GDAL_VERSION}.tar.gz &>>
> > /dev/null
> > cd $ROOTDIR/src/gdal-${GDAL_VERSION}CFLAGS="-O3 -pipe -march=native
> > -w"; CXXFLAGS="${CFLAGS}" ./configure --with-proj=$ROOTDIR --with-
> > cpp14 --with-crypto=yes --with-liblzma --with-python --with-
> > geos=$ROOTDIR --with-spatialite --with-openjpeg=$ROOTDIR --with-
> > hdf5=$ROOTDIR --with-netcdf=$ROOTDIR --with-pg --with-curl --with-
> > png make -s -j$(nproc) &>> /dev/null make installldconfig make
> > clean &>> /dev/null
> > echo "Install GDAL python" cd $ROOTDIR/src/gdal-
> > ${GDAL_VERSION}/swig/pythonpython3 setup.py build && python3
> > setup.py install
> > I got this error and I am unable to complete the compilation :
> > make[1] : on entre dans le répertoire « /usr/src/gdal-
> > 3.2.1/apps »/bin/bash /usr/src/gdal-3.2.1/libtool --mode=link --
> > silent g++ gdalinfo_bin.lo /usr/src/gdal-3.2.1/libgdal.la -o
> > gdalinfo/usr/bin/ld: /usr/src/gdal-3.2.1/.libs/libgdal.so:
> > undefined reference to `opj_encoder_set_extra_options'collect2:
> > error: ld returned 1 exit statusmake[1]: *** [GNUmakefile:90:
> > gdalinfo] Error 1make[1] : on quitte le répertoire « /usr/src/gdal-
> > 3.2.1/apps »make: *** [GNUmakefile:120: apps-target] Error 2
> > It seems that the reference to `opj_encoder_set_extra_options' is
> > linked to the OpenJPEG librairy but I didn't have any errors when I
> > compiled manually OpenJPEG librairy. And I didn't find any clue on
> > internet to fix it.
> > Did I miss something in my compilation process ?
> > Thanks in adavance for your advice.
> > Sylvain
> Sylvain
Sylvain
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20210209/db5c5a3d/attachment.html>
