[gdal-dev] Compiling GDAL with HDF4 support
Markus Metz
markus.metz.giswork at gmail.com
Mon Feb 8 11:22:55 PST 2021
Is /usr/local/lib64 known to your system as a path to libraries? Check the
env var LD_LIBRARY_PATH or add "/usr/local/lib64" to some file in
/etc/ld.so.conf.d/ followed by "ldconfig" as root.
You can also set the var LDFLAGS for configure if you have libraries in a
nonstandard directory, such as
LDFLAGS="/usr/local/lib64" ./configure ...
HTH,
Markus
On Mon, Feb 8, 2021 at 10:13 AM Hernán De Angelis <
variablestarlight at gmail.com> wrote:
> On 2021-02-08 10:09, Andrew C Aitchison wrote:
> > On Mon, 8 Feb 2021, Hernán De Angelis wrote:
> >> Hi everyone
> >> I am trying to compile GDAL 3.2.1 with HDF4 4.2.15. HDF4 is in
> >> /usr/local and subdirectories, but GDAL configure (--with-hdf4)
> >> complains:
> >> checking for SDreaddata in -lmfhdfalt... no
> >> checking for SDreaddata in -lmfhdf... no
> >> checking for SDreaddata in -lhdf4... no
> >> configure: error: HDF4 support requested with arg "yes", but neither
> >> hdf4 nor mfhdf lib found
> >> Yet, in /usr/local/lib64 I find:
> >> /usr/local/lib64/libhdf4.settings
> >> /usr/local/lib64/libmfhdf.a
> >> /usr/local/lib64/libmfhdf.la
> >> Am I missing something? Working in openSUSE Tumbleweed.
> > Possibly something like
> > configure --with-hdf4=/usr/local/lib64
> > rather than
> Thanks for your suggestion, Andrew, but I tried that of course before
> and did not work. Same result.
> /H.
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20210208/ab73e20a/attachment-0001.html>
