[gdal-dev] Compiling GDAL with HDF4 support
Hernán De Angelis
variablestarlight at gmail.com
Mon Feb 8 23:33:00 PST 2021
On 2021-02-08 20:22, Markus Metz wrote:
> Is /usr/local/lib64 known to your system as a path to libraries? Check
> the env var LD_LIBRARY_PATH or add "/usr/local/lib64" to some file in
> /etc/ld.so.conf.d/ followed by "ldconfig" as root.
> You can also set the var LDFLAGS for configure if you have libraries
> in a nonstandard directory, such as
> LDFLAGS="/usr/local/lib64" ./configure ...
Thank you for your suggestion, Markus, but /usr/local/Lib64 is in the
library path.
/H.
