[gdal-dev] Converting KML data with styles to GeoJSON output
MRRAJESH rajeshreddy82 at gmail.com
Tue Feb 9 01:02:02 PST 2021
Below are the input sample KML, out GeoJSON, and missing values.
*Sample KML:*
<kml xmlns="http://www.opengis.net/kml/2.2">
  <Document>
    <Placemark>
      <name>Building 41</name>
      <styleUrl>#transBluePoly</styleUrl>
      <Polygon>
        <extrude>1</extrude>
        <altitudeMode>relativeToGround</altitudeMode>
        <outerBoundaryIs>
          <LinearRing>
            <coordinates> -122.0857412771483,37.42227033155257,17
              -122.0858169768481,37.42231408832346,17
              -122.085852582875,37.42230337469744,17
              -122.0858799945639,37.42225686138789,17
              -122.0858860101409,37.4222311076138,17
              -122.0858069157288,37.42220250173855,17
              -122.0858379542653,37.42214027058678,17
              -122.0856732640519,37.42208690214408,17
              -122.0856022926407,37.42214885429042,17
              -122.0855902778436,37.422128290487,17
              -122.0855841672237,37.42208171967246,17
              -122.0854852065741,37.42210455874995,17
              -122.0855067264352,37.42214267949824,17
              -122.0854430712915,37.42212783846172,17
              -122.0850990714904,37.42251282407603,17
              -122.0856769818632,37.42281815323651,17
              -122.0860162273783,37.42244918858722,17
              -122.0857260327004,37.42229239604253,17
            </coordinates>
          </LinearRing>
        </outerBoundaryIs>
      </Polygon>
    </Placemark>
  </Document>
</kml>
*GEOJSON Output:*
"type": "FeatureCollection",
"name": "kml_geometry_style",
"crs": { "type": "name", "properties": { "name":
"urn:ogc:def:crs:OGC:1.3:CRS84" } },
"features": [
{ "type": "Feature", "properties": { "Name": "Building 41", "altitudeMode":
"relativeToGround", "tessellate": -1, "extrude": 1, "visibility": -1 },
"geometry": { "type": "Polygon", "coordinates": [ [ [ -122.085741277148301,
37.422270331552568, 17.0 ], [ -122.085816976848093, 37.422314088323461, 17.0
], [ -122.085852582875006, 37.422303374697442, 17.0 ], [
-122.085879994563896, 37.422256861387893, 17.0 ], [ -122.085886010140896,
37.422231107613797, 17.0 ], [ -122.085806915728796, 37.422202501738553, 17.0
], [ -122.085837954265301, 37.42214027058678, 17.0 ], [
-122.085673264051906, 37.422086902144081, 17.0 ], [ -122.085602292640701,
37.42214885429042, 17.0 ], [ -122.085590277843593, 37.422128290487002, 17.0
], [ -122.085584167223701, 37.422081719672462, 17.0 ], [
-122.085485206574106, 37.42210455874995, 17.0 ], [ -122.085506726435199,
37.422142679498243, 17.0 ], [ -122.085443071291493, 37.422127838461719, 17.0
], [ -122.085099071490404, 37.42251282407603, 17.0 ], [
-122.085676981863202, 37.422818153236513, 17.0 ], [ -122.086016227378295,
37.422449188587223, 17.0 ], [ -122.085726032700407, 37.422292396042529, 17.0
], [ -122.085741277148301, 37.422270331552568, 17.0 ] ] ] } }
*MISSING part:*
Sent from: http://osgeo-org.1560.x6.nabble.com/GDAL-Dev-f3742093.html
