[gdal-dev] Converting KML data with styles to GeoJSON output
Richard Duivenvoorde rdmailings at duif.net
Tue Feb 9 01:35:55 PST 2021
Hi MRRAJESH,
GeoJSON does not contain style information, it is pure data.
KML indeed can contain both data AND styling.
But if you convert KML to GeoJSON, you only get data, because... GeoJSON does not define style/colors.
You need to style/color your geojson in your client.
In clients like: https://geojson.io you can add some styling (see below) but that is not part of the geojson spec, it is (for what I know) client specific. ogr2ogr is only following the standards
Regards,
PS geojson adds some nonstandard css like attributes to make it possible to share geojson with some colors:
load this in https://geojson.io
  "type": "FeatureCollection",
  "features": [
      "type": "Feature",
      "properties": {
        "stroke": "#ed0d0d",
        "stroke-width": 2,
        "stroke-opacity": 1,
        "fill": "#336af7",
        "fill-opacity": 0.5
      "geometry": {
        "type": "Polygon",
        "coordinates": [
              40.42968749999999,
              50.736455137010665
              36.2109375,
              43.83452678223682
              50.2734375,
              38.8225909761771
              53.78906249999999,
              42.5530802889558
              52.03125,
              47.989921667414194
              50.625,
              50.28933925329178
              46.05468749999999,
              54.36775852406841
              40.42968749999999,
              50.736455137010665
On 2/9/21 10:02 AM, MRRAJESH wrote:
> Below are the input sample KML, out GeoJSON, and missing values.
> *Sample KML:*
> <?xml version="1.0" encoding="UTF-8"?>
> <kml xmlns="http://www.opengis.net/kml/2.2">
>   <Document>
>     <Placemark>
>       <name>Building 41</name>
>       <styleUrl>#transBluePoly</styleUrl>
>       <Polygon>
>         <extrude>1</extrude>
>         <altitudeMode>relativeToGround</altitudeMode>
>         <outerBoundaryIs>
>           <LinearRing>
>             <coordinates> -122.0857412771483,37.42227033155257,17
>               -122.0858169768481,37.42231408832346,17
>               -122.085852582875,37.42230337469744,17
>               -122.0858799945639,37.42225686138789,17
>               -122.0858860101409,37.4222311076138,17
>               -122.0858069157288,37.42220250173855,17
>               -122.0858379542653,37.42214027058678,17
>               -122.0856732640519,37.42208690214408,17
>               -122.0856022926407,37.42214885429042,17
>               -122.0855902778436,37.422128290487,17
>               -122.0855841672237,37.42208171967246,17
>               -122.0854852065741,37.42210455874995,17
>               -122.0855067264352,37.42214267949824,17
>               -122.0854430712915,37.42212783846172,17
>               -122.0850990714904,37.42251282407603,17
>               -122.0856769818632,37.42281815323651,17
>               -122.0860162273783,37.42244918858722,17
>               -122.0857260327004,37.42229239604253,17
>             </coordinates>
>           </LinearRing>
>         </outerBoundaryIs>
>       </Polygon>
>     </Placemark>
>   </Document>
> </kml>
> *GEOJSON Output:*
> "name": "kml_geometry_style",
> "crs": { "type": "name", "properties": { "name":
> "urn:ogc:def:crs:OGC:1.3:CRS84" } },
> "features": [
> { "type": "Feature", "properties": { "Name": "Building 41", "altitudeMode":
> "relativeToGround", "tessellate": -1, "extrude": 1, "visibility": -1 },
> "geometry": { "type": "Polygon", "coordinates": [ [ [ -122.085741277148301,
> 37.422270331552568, 17.0 ], [ -122.085816976848093, 37.422314088323461, 17.0
> ], [ -122.085852582875006, 37.422303374697442, 17.0 ], [
> -122.085879994563896, 37.422256861387893, 17.0 ], [ -122.085886010140896,
> 37.422231107613797, 17.0 ], [ -122.085806915728796, 37.422202501738553, 17.0
> ], [ -122.085837954265301, 37.42214027058678, 17.0 ], [
> -122.085673264051906, 37.422086902144081, 17.0 ], [ -122.085602292640701,
> 37.42214885429042, 17.0 ], [ -122.085590277843593, 37.422128290487002, 17.0
> ], [ -122.085584167223701, 37.422081719672462, 17.0 ], [
> -122.085485206574106, 37.42210455874995, 17.0 ], [ -122.085506726435199,
> 37.422142679498243, 17.0 ], [ -122.085443071291493, 37.422127838461719, 17.0
> ], [ -122.085099071490404, 37.42251282407603, 17.0 ], [
> -122.085676981863202, 37.422818153236513, 17.0 ], [ -122.086016227378295,
> 37.422449188587223, 17.0 ], [ -122.085726032700407, 37.422292396042529, 17.0
> ], [ -122.085741277148301, 37.422270331552568, 17.0 ] ] ] } }
> *MISSING part:*
> Sent from: http://osgeo-org.1560.x6.nabble.com/GDAL-Dev-f3742093.html
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
