[gdal-dev] mosaicking files with partial overlap and binary mask
Daniele Romagnoli daniele.romagnoli at geo-solutions.it
Thu Feb 11 06:21:35 PST 2021
Thanks for the feedback, Patrick.
I have downloaded the latest build from GisInternals and it worked as
expected.
I have another question.
It looks like warping an input file containing a binary mask isn't
preserving the binary mask on the output.
Should I specify any flag for that?
Thanks for the help.
Regards,
Daniele
On Thu, Jan 28, 2021 at 4:23 PM Patrick Young <
patrick.mckendree.young at gmail.com> wrote:
> I do not!
> If you want to try it out without building latest yourself and can use
> docker, you can snag one of the latest containers here and see if it works
> for you:
> https://hub.docker.com/r/osgeo/gdal/tags?page=1&ordering=last_updated
> Best,
> Patrick
> On Thu, Jan 28, 2021 at 2:12 AM Daniele Romagnoli <
> daniele.romagnoli at geo-solutions.it> wrote:
>> Hi Patrick,
>> nice!
>> Thanks for the feedback.
>> Do you have any info about eventual backports to previous versions?
>> Regards,
>> Daniele
>> On Thu, Jan 28, 2021 at 12:02 AM Patrick Young <
>>> Hi Daniele,
>>> Even added this functionality to VRTs just recently, see
>>> https://lists.osgeo.org/pipermail/gdal-dev/2020-December/053178.html
>>> I think it is slated for GDAL 3.3 but you could always build the
>>> bleeding edge.
>>> Patrick
>>> On Wed, Jan 27, 2021 at 3:50 AM Daniele Romagnoli <
>>>> Hi list,
>>>> I have some TIFF datasets with partially overlapping edges and embedded
>>>> binary masks to keep into account which parts along the edges should be
>>>> masked out.
>>>> When showing all the images on QGIS it looks good since the binary mask
>>>> do its job by making the "black/white" overlapping edge masked out.
>>>> Now I need to create a single TIF from all of these images.
>>>> I have tried with gdalbuildvrt but it doesn't produce good result.
>>>> Checking the doc I saw this:
>>>> *If there is some amount of spatial overlapping between files [...]
>>>> currently, alpha channel is not taken into account to do alpha compositing
>>>> (so a source with alpha=0 appearing on top of another source will override
>>>> is content). This might be changed in later versions.  *
>>>> So I think it's expected and I have switched to gdal_merge.py.
>>>> It works better since it does alpha compositing but it looks like the
>>>> result doesn't preserve the binary mask which I still need since I have M
>>>> groups of N files which I need to process in 2 passes:
>>>> - the inner group of N files get merged using the binary mask to a
>>>> bigger file.
>>>> - all the M bigger files get mosaicked again to a single huge file.
>>>> I will spend some more time in testing different attempts.
>>>> In the meantime, do you have any suggestion or past experience on how
>>>> to deal with that?
>>>> Side note: I have vague memory of gdal_merge being somehow memory
>>>> bounded, throwing memory allocation errors when trying to compose big
>>>> images. This is why in the past I was using gdalbuildvrt to do composition
>>>> (without overlapping).
>>>> Thanks in advance.
>>>> Regards,
>>>> Daniele
>>>> Regards,
>>>> Daniele Romagnoli
>>>> GeoServer Professional Services from the experts! Visit
>>>> http://goo.gl/it488V for more information.
>>>> Ing. Daniele Romagnoli
>>>> Senior Software Engineer
>>>> GeoSolutions S.A.S.
>>>> Via di Montramito 3/A
>>>> 55054  Massarosa (LU)
>>>> Italy
>>>> phone: +39 0584 962313
>>>> fax:      +39 0584 1660272
>>>> http://www.geo-solutions.it
>>>> http://twitter.com/geosolutions_it
>>>> Con riferimento alla normativa sul trattamento dei dati personali (Reg.
>>>> UE 2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si
>>>> precisa che ogni circostanza inerente alla presente email (il suo
>>>> contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è
>>>> riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il
>>>> messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra
>>>> operazione è illecita. Le sarei comunque grato se potesse darmene notizia.
>>>> This email is intended only for the person or entity to which it is
>>>> addressed and may contain information that is privileged, confidential or
>>>> otherwise protected from disclosure. We remind that - as provided by
>>>> European Regulation 2016/679 “GDPR” - copying, dissemination or use of this
>>>> e-mail or the information herein by anyone other than the intended
>>>> recipient is prohibited. If you have received this email by mistake, please
>>>> notify us immediately by telephone or e-mail.
>>>> _______________________________________________
>>>> gdal-dev mailing list
>>>> gdal-dev at lists.osgeo.org
>>>> https://lists.osgeo.org/mailman/listinfo/gdal-dev
>> Regards,
>> Daniele Romagnoli
>> GeoSolutions S.A.S.
>> Italy
Regards,
Daniele Romagnoli
GeoServer Professional Services from the experts! Visit http://goo.gl/it488V
GeoSolutions S.A.S.
Italy
Con riferimento alla normativa sul trattamento dei dati personali (Reg. UE
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20210211/34827668/attachment-0001.html>
