[gdal-dev] WMTS services error
Elena Ruiz eruiz at aplitop.com
Fri Feb 12 05:05:03 PST 2021
Hello, my goal is to obtain images of both WMS and WMTS web services using GDAL, with the CRS that each service provides, in the case of the example, how can I do then to obtain images in EPSG: 4326 or any other CRS that have changed axes? Should a parameter be added to the gdal_translate call? What would be the correct way to obtain this type of images using gdal applications like gadlinfo and gdaltranslate?
I have found very little information about this on the web, many thanks and best regards
Elena Ruiz
[https://www.aplitop.com/descargas/logo.png]
Sofware Development & Technical Support
Tel.: +34 952 43 97 71
www.aplitop.com
<http://www.aplitop.com/Product/es/6/5/tcptunnel>
<http://www.aplitop.com/New/es/281/mdt-75-a-la-venta>
De: Travis Kirstine <traviskirstine at gmail.com>
Enviado el: jueves, 11 de febrero de 2021 20:20
Para: Elena Ruiz <eruiz at aplitop.com>
CC: gdal-dev at lists.osgeo.org
Asunto: Re: [gdal-dev] WMTS services error
Elena,
I'm not exactly sure what is causing the issue but if you look at the capabilities of the 4326 tilematrixset compared to the InspireCRS84Quad the topleftcorner coordinates are reversed.  My guess gdal is expecting a X Y order.
<TileMatrixSet>
<ows:Identifier>InspireCRS84Quad</ows:Identifier>
<ows:SupportedCRS>http://www.opengis.net/def/crs/OGC/1.3/CRS84</ows:SupportedCRS>
<TileMatrix>
<ows:Identifier>0</ows:Identifier>
<ScaleDenominator>2.79541132014358E8</ScaleDenominator>
<TopLeftCorner>-180.0 90.0</TopLeftCorner>
<TileWidth>256</TileWidth>
<TileHeight>256</TileHeight>
<MatrixWidth>2</MatrixWidth>
<MatrixHeight>1</MatrixHeight>
</TileMatrix>
<TileMatrixSet>
<ows:Identifier>EPSG:4326</ows:Identifier>
<ows:SupportedCRS>EPSG:4326</ows:SupportedCRS>
<!--  crs="urn:ogc:def:crs:EPSG::4326"  -->
<TileMatrix>
<ows:Identifier>EPSG:4326:0</ows:Identifier>
<ScaleDenominator>2.795411320143589E8</ScaleDenominator>
<TopLeftCorner>90.0 -180.0</TopLeftCorner>
</TileMatrix>
On Thu, 11 Feb 2021 at 11:51, Elena Ruiz <eruiz at aplitop.com<mailto:eruiz at aplitop.com>> wrote:
Hello, I´m trying call web services (WMTS and WMS) using GDAL 3.0.2, but I have a problem with this example:
gdal_translate "WMTS:http://www.ign.es/wmts/pnoa-ma?request=GetCapabilities&service=WMTS,layer=OI.OrthoimageCoverage,tilematrixset=EPSG:4326" d://wmts_bm.xml -of WMTS
ERROR 1: Invalid dataset dimensions : -135056383 x -167901439
gdal_translate "WMTS:http://www.ign.es/wmts/pnoa-ma?request=GetCapabilities&service=WMTS,layer=OI.OrthoimageCoverage,tilematrixset=EPSG:25830" d://wmts_bm.xml -of WMTS
Input file size is 20616192, 26817505
In this server http://www.ign.es/wmts/pnoa-ma have available the next SRS :
SUBDATASET_1_NAME=WMTS:http://www.ign.es/wmts/pnoa-ma?request=GetCapabilities&service=WMTS,layer=OI.OrthoimageCoverage,tilematrixset=InspireCRS84Quad
SUBDATASET_2_NAME=WMTS:http://www.ign.es/wmts/pnoa-ma?request=GetCapabilities&service=WMTS,layer=OI.OrthoimageCoverage,tilematrixset=EPSG:4326
SUBDATASET_3_NAME=WMTS:http://www.ign.es/wmts/pnoa-ma?request=GetCapabilities&service=WMTS,layer=OI.OrthoimageCoverage,tilematrixset=EPSG:4258
SUBDATASET_4_NAME=WMTS:http://www.ign.es/wmts/pnoa-ma?request=GetCapabilities&service=WMTS,layer=OI.OrthoimageCoverage,tilematrixset=EPSG:25830
SUBDATASET_5_NAME=WMTS:http://www.ign.es/wmts/pnoa-ma?request=GetCapabilities&service=WMTS,layer=OI.OrthoimageCoverage,tilematrixset=GoogleMapsCompatible
But when I want Know the information or download a image in certain coordinates  with EPSG:4326, it returns an error “ERROR 1: Invalid dataset dimensions : -135056383 x -167901439”, with EPSG:25830 works fine. I don`t understand this error, someone could help me?
Thank you and regards
[https://www.aplitop.com/descargas/firma1.jpg]
Elena Ruiz
Tel. +34 952 43 97 71
Sumatra, 9 - 29190 Málaga (Spain)
www.aplitop.com<http://www.aplitop.com>
[cid:image002.jpg at 01D70148.0DA21C80]<https://www.facebook.com/AplitopSL/>   [cid:image004.jpg at 01D70148.0DA21C80] <https://twitter.com/aplitop>    [cid:image006.jpg at 01D70148.0DA21C80] <https://www.linkedin.com/company/aplitop>    [cid:image008.png at 01D70148.0DA21C80] <https://www.youtube.com/user/aplitop>
In accordance with the provisions of the European Regulation of Data Protection 2016/679 (Reglamento Europeo de Protección de Datos 2016/679), we inform you that the data and the information you provide us through this medium will be used by APLITOP, S.L., with C.I.F. B-92543396 and with address at C / Sumatra, 9, Malaga, 29190, in order to answer your questions and inform you about our products. The data provided will be kept as long as it does not request its cessation and will not be transferred to third parties except in cases where there is a legal obligation. You have the right to access your personal data, correct inaccurate data or request its deletion when the data is no longer necessary for the purposes that were collected, as well as any rights recognized in the RGPD 2016/679
gdal-dev mailing list
gdal-dev at lists.osgeo.org<mailto:gdal-dev at lists.osgeo.org>
https://lists.osgeo.org/mailman/listinfo/gdal-dev
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20210212/2fd3dcfa/attachment-0001.html>
Type: image/jpeg
Desc: image002.jpg
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20210212/2fd3dcfa/attachment-0003.jpg>
Type: image/jpeg
Desc: image004.jpg
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20210212/2fd3dcfa/attachment-0004.jpg>
Type: image/jpeg
Desc: image006.jpg
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20210212/2fd3dcfa/attachment-0005.jpg>
Type: image/png
Desc: image008.png
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20210212/2fd3dcfa/attachment-0001.png>
