[gdal-dev] WMTS services error
Travis Kirstine traviskirstine at gmail.com
Fri Feb 12 05:26:03 PST 2021
Elena
This appears to be a bug in wmts driver in gdal, I would suggest filing a
issue
The below is from the OGC Two Dimensional Tile Matrix Set specs, section d2
http://docs.opengeospatial.org/is/17-083r2/17-083r2.html
"NOTE4: Some implementers prefer to define this TileMatrixSet using the CRS
http://www.opengis.net/def/crs/EPSG/0/4326. The definition is the same
except that CRS coordinates are expressed in latitude, longitude order,
affecting the TopLeftCorner and the BBox encoding only".
On Fri, 12 Feb 2021 at 08:05, Elena Ruiz <eruiz at aplitop.com> wrote:
> Hello, my goal is to obtain images of both WMS and WMTS web services using
> GDAL, with the CRS that each service provides, in the case of the example,
> how can I do then to obtain images in EPSG: 4326 or any other CRS that have
> changed axes? Should a parameter be added to the gdal_translate call? What
> would be the correct way to obtain this type of images using gdal
> applications like gadlinfo and gdaltranslate?
> I have found very little information about this on the web, many thanks
> and best regards
> *Elena Ruiz*
> Sofware Development & Technical Support
> Tel.: +34 952 43 97 71
> *www.aplitop.com <http://www.aplitop.com>*
> <http://www.aplitop.com/Product/es/6/5/tcptunnel>
> <http://www.aplitop.com/New/es/281/mdt-75-a-la-venta>
> *De:* Travis Kirstine <traviskirstine at gmail.com>
> *Enviado el:* jueves, 11 de febrero de 2021 20:20
> *Para:* Elena Ruiz <eruiz at aplitop.com>
> *CC:* gdal-dev at lists.osgeo.org
> *Asunto:* Re: [gdal-dev] WMTS services error
> Elena,
> I'm not exactly sure what is causing the issue but if you look at the
> capabilities of the 4326 tilematrixset compared to the InspireCRS84Quad the
> topleftcorner coordinates are reversed.  My guess gdal is expecting a X Y
> order.
> <TileMatrixSet>
> <ows:Identifier>InspireCRS84Quad</ows:Identifier>
> <ows:SupportedCRS>http://www.opengis.net/def/crs/OGC/1.3/CRS84
> </ows:SupportedCRS>
> <TileMatrix>
> <ows:Identifier>0</ows:Identifier>
> <ScaleDenominator>2.79541132014358E8</ScaleDenominator>
> <TopLeftCorner>-180.0 90.0</TopLeftCorner>
> <TileWidth>256</TileWidth>
> <TileHeight>256</TileHeight>
> <MatrixWidth>2</MatrixWidth>
> <MatrixHeight>1</MatrixHeight>
> </TileMatrix>
> <TileMatrixSet>
> <ows:Identifier>EPSG:4326</ows:Identifier>
> <ows:SupportedCRS>EPSG:4326</ows:SupportedCRS>
> <!--  crs="urn:ogc:def:crs:EPSG::4326"  -->
> <TileMatrix>
> <ows:Identifier>EPSG:4326:0</ows:Identifier>
> <ScaleDenominator>2.795411320143589E8</ScaleDenominator>
> <TopLeftCorner>90.0 -180.0</TopLeftCorner>
> </TileMatrix>
> On Thu, 11 Feb 2021 at 11:51, Elena Ruiz <eruiz at aplitop.com> wrote:
> Hello, I´m trying call web services (WMTS and WMS) using GDAL 3.0.2, but I
> have a problem with this example:
> gdal_translate "WMTS:
> http://www.ign.es/wmts/pnoa-ma?request=GetCapabilities&service=WMTS,layer=OI.OrthoimageCoverage,tilematrixset=EPSG:4326"
> d://wmts_bm.xml -of WMTS
> ERROR 1: Invalid dataset dimensions : -135056383 x -167901439
> http://www.ign.es/wmts/pnoa-ma?request=GetCapabilities&service=WMTS,layer=OI.OrthoimageCoverage,tilematrixset=EPSG:25830"
> Input file size is 20616192, 26817505
> In this server http://www.ign.es/wmts/pnoa-ma have available the next SRS
> SUBDATASET_1_NAME=WMTS:
> http://www.ign.es/wmts/pnoa-ma?request=GetCapabilities&service=WMTS,layer=OI.OrthoimageCoverage,tilematrixset=InspireCRS84Quad
> SUBDATASET_2_NAME=WMTS:
> SUBDATASET_3_NAME=WMTS:
> http://www.ign.es/wmts/pnoa-ma?request=GetCapabilities&service=WMTS,layer=OI.OrthoimageCoverage,tilematrixset=EPSG:4258
> SUBDATASET_4_NAME=WMTS:
> SUBDATASET_5_NAME=WMTS:
> http://www.ign.es/wmts/pnoa-ma?request=GetCapabilities&service=WMTS,layer=OI.OrthoimageCoverage,tilematrixset=GoogleMapsCompatible
> But when I want Know the information or download a image in certain
> coordinates  with EPSG:4326, it returns an error “ERROR 1: Invalid dataset
> dimensions : -135056383 x -167901439”, with EPSG:25830 works fine. I don`t
> understand this error, someone could help me?
> Thank you and regards
> *Elena Ruiz *
> Tel. +34 952 43 97 71
> Sumatra, 9 - 29190 Málaga (Spain)
> <https://www.facebook.com/AplitopSL/>   <https://twitter.com/aplitop>
> <https://www.linkedin.com/company/aplitop>
> <https://www.youtube.com/user/aplitop>
> In accordance with the provisions of the European Regulation of Data
> Protection 2016/679 (Reglamento Europeo de Protección de Datos 2016/679),
> we inform you that the data and the information you provide us through this
> medium will be used by APLITOP, S.L., with C.I.F. B-92543396 and with
> address at C / Sumatra, 9, Malaga, 29190, in order to answer your questions
> and inform you about our products. The data provided will be kept as long
> as it does not request its cessation and will not be transferred to third
> parties except in cases where there is a legal obligation. You have the
> right to access your personal data, correct inaccurate data or request its
> deletion when the data is no longer necessary for the purposes that were
> collected, as well as any rights recognized in the RGPD 2016/679
> gdal-dev mailing list
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20210212/bdae0eeb/attachment-0001.html>
Type: image/jpeg
Desc: not available
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20210212/bdae0eeb/attachment-0003.jpg>
Type: image/jpeg
Desc: not available
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20210212/bdae0eeb/attachment-0004.jpg>
Type: image/jpeg
Desc: not available
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20210212/bdae0eeb/attachment-0005.jpg>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20210212/bdae0eeb/attachment-0001.png>
