[gdal-dev] Requesting a transparent image from a WMS server...
jratike80 jukka.rahkonen at maanmittauslaitos.fi
Fri Feb 19 05:55:25 PST 2021
Try
gdal_translate
"WMS:https://maps-public.geo.nyu.edu:443/geoserver/wms?SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&LAYERS=sdr%3Anyu_2451_43745&SRS=EPSG:4326&BBOX=-119.265762329102,35.2621765136719,-118.825294494629,35.4424705505371&format=image/png&transparent=TRUE"
service.xml -of WMS
Notice the the format must be something that supports transparency so
image/jpeg does not work.
-Jukka Rahkonen-
Carl Godkin-2 wrote
> Hi,
> I'm generating WMS service description files as described here:
> https://gdal.org/drivers/raster/wms.html#generation-of-wms-service-description-xml-file
> This works well, but I wonder if there's a way to request the image from
> the WMS server to be transparent.
> If I use gdal_translate to create the WMS service description file like
> this:
> gdal_translate "WMS:
> https://maps-public.geo.nyu.edu:443/geoserver/wms?SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&LAYERS=sdr%3Anyu_2451_43745&SRS=EPSG:4326&BBOX=-119.265762329102,35.2621765136719,-118.825294494629,35.4424705505371"
> service.xml -of WMS
> then I get this:
> <GDAL_WMS>
> <Service name="WMS">
> <Version>
> 1.1.1
> </Version>
> <ServerUrl>
> </ServerUrl>
> <Layers>
> </Layers>
> <SRS>
> EPSG:4326
> </SRS>
> <ImageFormat>
> image/jpeg
> </ImageFormat>
> <Transparent>
> FALSE
> </Transparent>
> <BBoxOrder>
> xyXY
> </BBoxOrder>
> </Service>
> <DataWindow>
> <UpperLeftX>
> -119.265762329102
> </UpperLeftX>
> <UpperLeftY>
> 35.4424705505371
> </UpperLeftY>
> <LowerRightX>
> -118.825294494629
> </LowerRightX>
> <LowerRightY>
> 35.2621765136719
> </LowerRightY>
> <SizeX>
> 1073741824
> </SizeX>
> <SizeY>
> 439508252
> </SizeY>
> </DataWindow>
> <BandsCount>
> 3
> </BandsCount>
> <BlockSizeX>
> 1024
> </BlockSizeX>
> <BlockSizeY>
> 1024
> </BlockSizeY>
> <OverviewCount>
> 20
> </OverviewCount>
> </GDAL_WMS>
> I have discovered that if I slightly edit three lines the service
> description like this:
> <ImageFormat>
> image/geotiff
> </ImageFormat>
> <Transparent>
> TRUE
> </Transparent>
> <BandsCount>
> 4
> </BandsCount>
> then my output image is transparent if I compare these two output files:
> gdal_translate -outsize 512 512 -projwin -119.1 35.4 -119 35.3 service.xml
> bakersfield.tif
> service_trans.xml bakersfield_trans.tif
> Are there some options I can use in the first gdal_translate command above
> to generate the WMS description file so that
> it retrieves transparent images if the server supports transparency?
> (I am actually creating the service description file in C++ code using
> CreateCopy, but I believe it's easy to prototype with the CLI.)
> Thanks very much,
> carl
> gdal-dev mailing list
> gdal-dev at .osgeo
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
Sent from: http://osgeo-org.1560.x6.nabble.com/GDAL-Dev-f3742093.html
