[gdal-dev] warp ARGB -> RGB gtiff-jpeg?
Idan Miara
idan at miara.com
Tue Feb 23 09:41:33 PST 2021
Hi Jukka,
Thanks for your reply!
I didn't think about using VRT.
Using VRT (-b 1 -b 2 -b 3) as an input to warp solved the problem.
Idan
On Sat, 20 Feb 2021 at 23:52, jratike80 <jukka.rahkonen at maanmittauslaitos.fi>
wrote:
> Hi,
> It is very cheap to use gdal_translate and VRT as intermediate format. As
> far as I know it is not possible to drop alpha with gdalwarp even it is
> possible to add alpha -dstalpha.
> -Jukka Rahkonen-
> Idan Miara wrote
> > Hi All,
> > Is it possible to use gdal_warp for warping the RGB bands of an ARGB
> > raster
> > as gtiff with jpeg compression (i.e. to drop the Alpha channel and
> > transform CRS). ?
> > gdal_transalte has translate_options["bandList"] = [1, 2, 3] for that,
> but
> > I can't find the equivalent for warp.
> > I could do it in two steps - save as a lossless gtiff and then use
> > gdal_transalte to make a jpeg-gtiff. Or use gdal_trasnlate to make a 3
> > band
> > lossless gtiff and then wrap it.
> > Can I do it in one step without an intermediate file?
> > Regards,
> > Idan.
> > gdal-dev mailing list
> > gdal-dev at .osgeo
> > https://lists.osgeo.org/mailman/listinfo/gdal-dev
> Sent from: http://osgeo-org.1560.x6.nabble.com/GDAL-Dev-f3742093.html
> gdal-dev at lists.osgeo.org
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20210223/865776df/attachment.html>
