[gdal-dev] ogr2ogr from gpx to postgis - track_fid not maintained for track_points
Michael Saupe msaupe at web.de
Fri Jan 1 09:04:11 PST 2021
Hello folks,
I am importing multiple gpx files into a postgis database. The tables 'tracks' and 'track_points' are created / updated.
The column track_fid in in the track_points table should be a reference to the track feature id as documented in https://gdal.org/drivers/vector/gpx.html, however it is always zero.
Is this a bug or am I missing something?
      Details
I am creating an empty database, then create postgis extension with 'CREATE EXTENSION POSTGIS'
I have two simple gpx files ( see attachments )
  * file1.gpx - containing 2 track segments - each with 3 track points
  * file2.gpx - containing 1 track segment  with 3 track points
I am using commands
ogr2ogr -f PostgreSQL -update -append "PG:dbname=testdb host=localhost user=postgres password=xx port=5432" file1.gpx
ogr2ogr -f PostgreSQL -update -append "PG:dbname=testdb host=localhost user=postgres password=xx port=5432" file2.gpx
Resulting data in 'tracks'
ogc_fid 	name 	cmt 	desc 	src 	link1_href 	link1_text 	link1_type 	link2_href 	link2_text 	link2_type 	number 	type 	wkb_geometry
1 	NULL 	NULL 	NULL 	NULL 	NULL 	NULL 	NULL 	NULL 	NULL 	NULL 	NULL 	NULL 	...
2 	NULL 	NULL 	NULL 	NULL 	NULL 	NULL 	NULL 	NULL 	NULL 	NULL 	NULL 	NULL 	...
ogc_fid 	track_fid 	track_seg_id 	track_seg_point_id 	ele 	time 	.... other columns omitted ...
1 	0 	0 	0 	1 	NULL
2 	0 	0 	1 	1 	NULL
3 	0 	0 	2 	1 	NULL
4 	0 	1 	0 	2 	NULL
5 	0 	1 	1 	2 	NULL
6 	0 	1 	2 	2 	NULL
7 	0 	0 	0 	3 	NULL
8 	0 	0 	1 	3 	NULL
9 	0 	0 	2 	3 	NULL
Expected:
1 	1
	0 	0 	1 	NULL
2 	1
	0 	1 	1 	NULL
3 	1
	0 	2 	1 	NULL
4 	1
	1 	0 	2 	NULL
5 	1
	1 	1 	2 	NULL
6 	1
	1 	2 	2 	NULL
7 	2
	0 	0 	3 	NULL
8 	2
	0 	1 	3 	NULL
9 	2
	0 	2 	3 	NULL
I also tried to omit -update -append, but same result.
Versions:
  * Postgres: "PostgreSQL 12.5 on x86_64-pc-linux-musl, compiled by gcc (Alpine 9.3.0) 9.3.0, 64-bit"
  * Postgis: "POSTGIS="3.0.3 0" [EXTENSION] PGSQL="120" GEOS="3.8.1-CAPI-1.13.3" PROJ="7.0.1" LIBXML="2.9.10" LIBJSON="0.14" LIBPROTOBUF="1.3.3" WAGYU="0.4.3 (Internal)""
  * Gdal: 3.2.0
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20210101/ad5f393b/attachment.html>
