[gdal-dev] ogr2ogr from gpx to postgis - track_fid not maintained for track_points
Michael Saupe
msaupe at web.de
Fri Jan 1 11:54:36 PST 2021
clarification: second table of my points is 'track_points'.
Also adding my 2 gpx files for reference:
*file1.gpx:*
<gpx version="1.1" xmlns="http://www.topografix.com/GPX/1/1">
<metadata>
</metadata>
<trk>
<trkseg>
<trkpt lat="49.250324000" lon="8.687196000">
<ele>1</ele>
</trkpt>
<trkpt lat="49.250019001" lon="8.687469003">
<ele>1</ele>
</trkpt>
<trkpt lat="49.249714001" lon="8.687742003">
<ele>1</ele>
</trkpt>
</trkseg>
<trkseg>
<trkpt lat="49.125652000" lon="8.714194000">
<ele>2</ele>
</trkpt>
<trkpt lat="49.125519000" lon="8.714731000">
<ele>2</ele>
</trkpt>
<trkpt lat="49.125414000" lon="8.715057001">
<ele>2</ele>
</trkpt>
</trkseg>
</trk>
</gpx>
*file2.gpx:*
<metadata>
</metadata>
<trk>
<trkseg>
<trkpt lat="49.11" lon="8.7">
<ele>3</ele>
</trkpt>
<trkpt lat="49.12" lon="8.7">
<ele>3</ele>
</trkpt>
<trkpt lat="49.13" lon="8.7">
<ele>3</ele>
</trkpt>
</trkseg>
</trk>
</gpx
Am 01.01.2021 um 18:04 schrieb Michael Saupe:
> Hello folks,
> I am importing multiple gpx files into a postgis database. The tables 'tracks' and 'track_points' are created / updated.
> The column track_fid in in the track_points table should be a reference to the track feature id as documented in https://gdal.org/drivers/vector/gpx.html, however it is always zero.
> Is this a bug or am I missing something?
> Details
> I am creating an empty database, then create postgis extension with 'CREATE EXTENSION POSTGIS'
> I have two simple gpx files ( see attachments )
> * file1.gpx - containing 2 track segments - each with 3 track points
> * file2.gpx - containing 1 track segment with 3 track points
> I am using commands
> ogr2ogr -f PostgreSQL -update -append "PG:dbname=testdb host=localhost user=postgres password=xx port=5432" file1.gpx
> ogr2ogr -f PostgreSQL -update -append "PG:dbname=testdb host=localhost user=postgres password=xx port=5432" file2.gpx
> Resulting data in 'tracks'
> ogc_fid name cmt desc src link1_href link1_text link1_type link2_href link2_text link2_type number type wkb_geometry
> 1 NULL NULL NULL NULL NULL NULL NULL NULL NULL NULL NULL NULL ...
> 2 NULL NULL NULL NULL NULL NULL NULL NULL NULL NULL NULL NULL ...
Resulting data in 'track_points'
ogc_fid track_fid track_seg_id track_seg_point_id ele time .... other columns omitted ...
1 0 0 0 1 NULL
2 0 0 1 1 NULL
3 0 0 2 1 NULL
4 0 1 0 2 NULL
5 0 1 1 2 NULL
6 0 1 2 2 NULL
7 0 0 0 3 NULL
8 0 0 1 3 NULL
9 0 0 2 3 NULL
> Expected:
> 1 1
> 0 0 1 NULL
> 2 1
> 0 1 1 NULL
> 3 1
> 0 2 1 NULL
> 4 1
> 1 0 2 NULL
> 5 1
> 1 1 2 NULL
> 6 1
> 1 2 2 NULL
> 7 2
> 0 0 3 NULL
> 8 2
> 0 1 3 NULL
> 9 2
> 0 2 3 NULL
> I also tried to omit -update -append, but same result.
> Versions:
> * Postgres: "PostgreSQL 12.5 on x86_64-pc-linux-musl, compiled by gcc (Alpine 9.3.0) 9.3.0, 64-bit"
> * Postgis: "POSTGIS="3.0.3 0" [EXTENSION] PGSQL="120" GEOS="3.8.1-CAPI-1.13.3" PROJ="7.0.1" LIBXML="2.9.10" LIBJSON="0.14" LIBPROTOBUF="1.3.3" WAGYU="0.4.3 (Internal)""
> * Gdal: 3.2.0
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20210101/dd506fa7/attachment-0001.html>
