[gdal-dev] How to read multi-band xyz files?
Even Rouault even.rouault at spatialys.com
Wed Jan 6 02:58:15 PST 2021
> Is there any way to get all the bands?
Not directly.
You could add a header line with the appropriate column names, by making the Z
column to point to a different column each time.
Even
http://www.spatialys.com
