[gdal-dev] How to read multi-band xyz files?
Rahkonen Jukka (MML)
jukka.rahkonen at maanmittauslaitos.fi
Tue Jan 5 11:42:20 PST 2021
It is possible to create multi-band xyz files with the gdal2xyz.py script. The usage and result is like this:
gdal2xyz -band 1 -band 2 -band 3 test.tif test.xyz
more test.xyz
0.500 0.500 255 255 255
1.500 0.500 255 255 255
2.500 0.500 255 255 255
3.500 0.500 255 255 255
However, in reading "the X, Y and Z columns (in that order) are assumed to be the first 3 columns of each line" as documented in https://gdal.org/drivers/raster/xyz.html and gdalinfo finds only the first band
gdalinfo test.xyz
Driver: XYZ/ASCII Gridded XYZ
Files: test.xyz
Size is 476, 468
Origin = (0.000000000000000,0.000000000000000)
Pixel Size = (1.000000000000000,1.000000000000000)
Corner Coordinates:
Upper Left ( 0.0000000, 0.0000000)
Lower Left ( 0.000, 468.000)
Upper Right ( 476.000, 0.000)
Lower Right ( 476.000, 468.000)
Center ( 238.000, 234.000)
Band 1 Block=476x1 Type=Byte, ColorInterp=Undefined
Min=0.000 Max=255.000
Is there any way to get all the bands?
-Jukka Rahkonen-
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20210105/6c05a2b7/attachment.html>
