[gdal-dev] Map warping
gp.saliola at gmail.com
Tue Jan 5 01:22:14 PST 2021
Hello,
I'm trying to warp a GeoTiff image from its datum/projection to EPSG:32633
(WGS84 UTM33 Nord).
These are the info about the source tiff file:
Driver: GTiff/GeoTIFF
Files: C:\Users\gpsal\Desktop\venezia.tif
Size is 10600, 3904
Coordinate System is:
PROJCS["WGS 84 / Pseudo-Mercator",
GEOGCS["WGS 84",
DATUM["WGS_1984",
SPHEROID["WGS 84",6378137,298.257223563,
AUTHORITY["EPSG","7030"]],
AUTHORITY["EPSG","6326"]],
PRIMEM["Greenwich",0,
AUTHORITY["EPSG","8901"]],
UNIT["degree",0.0174532925199433,
AUTHORITY["EPSG","9122"]],
AUTHORITY["EPSG","4326"]],
PROJECTION["Mercator_1SP"],
PARAMETER["central_meridian",0],
PARAMETER["scale_factor",1],
PARAMETER["false_easting",0],
PARAMETER["false_northing",0],
UNIT["metre",1,
AUTHORITY["EPSG","9001"]],
AXIS["Easting",EAST],
AXIS["Northing",NORTH],
EXTENSION["PROJ4","+proj=merc +a=6378137 +b=6378137 +lat_ts=0 +lon_0=0
+x_0=0 +y_0=0 +k=1 +units=m +nadgrids=@null +wktext +no_defs"],
AUTHORITY["EPSG","3857"]]
Data axis to CRS axis mapping: 1,2
PROJ.4 string is:
'+proj=merc +a=6378137 +b=6378137 +lat_ts=0 +lon_0=0 +x_0=0 +y_0=0 +k=1
+units=m +nadgrids=@null +wktext +no_defs'
Origin = (1335698.850769308628514,5704032.021438719704747)
Pixel Size = (3.356372516969551,-3.345286391264631)
Metadata:
AREA_OR_POINT=Area
TIFFTAG_RESOLUTIONUNIT=2 (pixels/inch)
TIFFTAG_XRESOLUTION=72
TIFFTAG_YRESOLUTION=72
Image Structure Metadata:
COMPRESSION=LZW
INTERLEAVE=PIXEL
Corner Coordinates:
Upper Left ( 1335698.851, 5704032.021) ( 11d59'55.63"E, 45d31'18.17"N)
Lower Left ( 1335698.851, 5690972.023) ( 11d59'55.63"E, 45d26'22.04"N)
Upper Right ( 1371276.399, 5704032.021) ( 12d19' 6.19"E, 45d31'18.17"N)
Lower Right ( 1371276.399, 5690972.023) ( 12d19' 6.19"E, 45d26'22.04"N)
Center ( 1353487.625, 5697502.022) ( 12d 9'30.91"E, 45d28'50.16"N)
Band 1 Block=10600x1 Type=Byte, ColorInterp=Red
Band 2 Block=10600x1 Type=Byte, ColorInterp=Green
Band 3 Block=10600x1 Type=Byte, ColorInterp=Blue
The result is a warped image but georeferencing is bad (difference of some
kilometers).
The problem is in the input map or what?
Thank you for your support.
Best regards,
Gian Paolo Saliola
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20210105/08b57d95/attachment.html>
