[gdal-dev] JPEG/PNG 12 bits GDAL python
jesus.moran at solute.es
Fri Jan 22 02:02:33 PST 2021
Hello and thank you in advance,
Im trying to generate png and jpeg 12 bits images from a GTiff single band
file with no success. I know is there a way to generate 12 bits images in
the GDAL command line as I have seen in some examples (gdal_translate
mandril_rgb.tif -co COMPRESS=JPEG -co PHOTOMETRIC=YCBCR -co NBITS=12
out.tif) but trying it with my singlebands tif files it only generates a
black image (with PHOTOMETRIC set to MINISBLACK). Is it only a method for
rgb files?
Searching in the python API I only can find gdalconst for 16, 32 and 64 bits
formats. Is there a way to do the same with 12 bits files?
Kind regards
<http://www.solute.es/>
Jesús Maria Morán Rosado
Project Engineer
Av. Cerro del Águila, 3, 28703 S.S. de los Reyes, Madrid
CONFIDENTIALITY: This e-mail and any attachments are confidential and may be
privileged. If you are not a named recipient, please notify the sender
immediately and do not disclose the contents to another person, use it for
any purpose or store or copy the information in any medium.
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20210122/8b1d435e/attachment.html>
Type: image/gif
Desc: not available
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20210122/8b1d435e/attachment.gif>
