[gdal-dev] Setting roles in PostGIS connection
Rahkonen Jukka (MML)
jukka.rahkonen at maanmittauslaitos.fi
Fri Jul 2 05:51:28 PDT 2021
Hi again,
GDAL is using the standand libpg-connect https://www.postgresql.org/docs/12/libpq-connect.html and that does not have support for defining roles during connect.
Do I understand right that your user "Joe" does not have direct CREATEDB privileges but gets them through the admins role? And because CREATEDB has a special handling https://www.postgresql.org/docs/current/role-membership.html there is no other way to let Joe to create db that through SET ROLE ADMINS.
Making GDAL to support
"-doo "PRELUDE_STATEMENTS=SET ROLE admins"
feels like a good idea but I have no idea about how difficult it would be to implement.
-Jukka Rahkonen-
-----Alkuperäinen viesti-----
Lähettäjä: Rahkonen Jukka (MML)
Lähetetty: perjantai 2. heinäkuuta 2021 14.40
Vastaanottaja: 'gdal-dev at lists.osgeo.org' <gdal-dev at lists.osgeo.org>
Aihe: Re: Setting roles in PostGIS connection
I wonder if writing the output into pgdump https://gdal.org/drivers/vector/pgdump.html and editing the SQL a bit could be used as a workaround.
-Jukka Rahkonen-
Pekka Sarkola wrote:
> Hi!
> We have a PostGIS database with login roles and group roles (like
> "admins", "editors" and "viewers"). We have defined that only "admins"
> can create new schemas and tables (among other privileges). My problem
> is that I'd like to use ogr2ogr to bulk load some data to a PostGIS
> database using ogr2ogr with a certain login role with "admins" role.
> It seems that it is not possible to define roles in PostgreSQL
> connection parameters (my first try) or in PostgreSQL driver options.
> I tried to use PREDUDE_STATEMENTS like: "-doo "PRELUDE_STATEMENTS=SET
> ROLE admins", but got warning "Warning 1: -doo ignored when creating
> the output datasource."
> Any solutions or suggestions?
> There is also similar case in QGIS: Supporting "set role" when
> connecting to a postgres database -
> https://github.com/qgis/QGIS/issues/42763
> Versions: GDAL 3.0.4, released 2020/01/28, PostgreSQL 12.7, PostGIS
> 3.1
> Rgs,
> Pekka
