[gdal-dev] Install GDAL on Arcmap 10.7
Matt.Wilkie at yukon.ca
Fri Jul 9 08:06:12 PDT 2021
Hello Sayena,
Gdal doesn’t have a graphic interface, it’s all command line utilities and programmer libraries. However Qgis (https://qgis.org/) is very well integrated with Gdal and is similar to ArcMap in a lot of ways and the members of the Qgis Community<https://qgis.org/en/site/forusers/support.html> are generally helpful if the docs don’t cover your situation.
Also within ArcMap you may have access to the Data Interoperability extension<https://desktop.arcgis.com/en/arcmap/latest/extensions/data-interoperability/what-is-the-data-interoperability-extension-.htm>.
-Matt
From: gdal-dev <gdal-dev-bounces at lists.osgeo.org> On Behalf Of Sayena
Sent: July 9, 2021 7:32 AM
To: gdal-dev at lists.osgeo.org
Subject: [gdal-dev] Install GDAL on Arcmap 10.7
*** External email: Do not click on links or attachments except from trusted senders. ***
Hello
I want to use Census data 2000 Urbanized area - They are in the ASCII format and apparently need a translator to convert them to lines/ polylines.
I searched in the internet and found out about the GDAL that can do the job. But just don't know how to use the graphic user interface with Arcmap 10.7
I do really appreciate your help
Sayena Farid Marandi
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20210709/eb6c7772/attachment.html>
