[gdal-dev] What is the gdal_translate scale exponent option for?
Even Rouault even.rouault at spatialys.com
Mon Jul 12 11:51:46 PDT 2021
Le 12/07/2021 à 20:48, Matt.Wilkie at yukon.ca a écrit :
> Hi Folks,
> |gdal_translate| has the option |-exponent <exp_val>|
> <https://gdal.org/programs/gdal_translate.html#cmdoption-gdal_translate-exponent>
> to use in conjunction with |-scale| that will
> /apply non-linear scaling with a power function. exp_val is the
> exponent of the power function (must be positive)./
> This describes what the function does at the mechanical level but not
> why or when it might be a good idea. What are appropriate scenarios to
> use this feature? How is it useful and what does it accomplish?
For example to perform https://en.wikipedia.org/wiki/Gamma_correction
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20210712/9853ce3d/attachment.html>
