[gdal-dev] GDAL fails to read projection with: Unsupported conversion method: Polar_Stereographic
Even Rouault even.rouault at spatialys.com
Wed Jul 28 08:18:15 PDT 2021
Louis-Phillippe,
this sounds like a bug. Please file a ticket at
https://github.com/OSGeo/gdal/issues/new with all the below details
Even
Le 28/07/2021 à 17:08, Rousseau Lambert,Louis-Philippe (ECCC) a écrit :
> Hi,
> I'm trying to read a projection in proj4 string from a NetCDF and gdal
> / proj fails to recognize the /*conversion method: Polar_Stereographic*/.
> The issue appears with any files in:
> https://dd.weather.gc.ca/model_riops/netcdf/forecast/polar_stereographic/2d/06/003/
> example gdalinfo request:
> /$ gdalinfo -proj4 input.nc//
> //Driver: netCDF/Network Common Data Format//
> //*ERROR 1: PROJ: proj_as_proj_string: Unsupported conversion method:
> Polar_Stereographic*//*
> *//*PROJ.4 string is:*//*
> //Origin = (-2500.000000000000000,8047500.000000000000000)//
> //Pixel Size = (5000.000000000000000,-5000.000000000000000)//
> //  SRS=GEOGCS["WGS 84",DATUM["WGS_1984",SPHEROID["WGS
> 84",6378137,298.257223563,AUTHORITY["EPSG","7030"]],AUTHORITY["EPSG","6326"]],PRIMEM["Greenwich",0,AUTHORITY["EPSG","8901"]],UNIT["degree",0.0174532925199433,AUTHORITY["EPSG","9122"]],AXIS["Latitude",NORTH],AXIS["Longitude",EAST],AUTHORITY["EPSG","4326"]]//
> //  X_BAND=1//
> //  X_DATASET=NETCDF:"dd_riops.nc":longitude//
> //  Y_BAND=1//
> //  Y_DATASET=NETCDF:"dd_riops.nc":latitude//
> //Corner Coordinates://
> //Upper Left  (   -2500.000, 8047500.000)//
> //Lower Left  (   -2500.000,   -2500.000)//
> //Upper Right ( 8847500.000, 8047500.000)//
> //Lower Right ( 8847500.000,   -2500.000)//
> //Center      ( 4422500.000, 4022500.000)//
> The gdal version I'm getting the error with: GDAL 3.1.3, and PROJ
> version: Rel. 7.2.0.
> I know this command previsously worked fine, using gdal GDAL 2.4.4 and
> proj Rel. 4.8.0 and I was able to get the PROJ4 string: '+proj=stere
> +lat_0=90 +lat_ts=59.99993768695209 +lon_0=-100 +k=0.93301243
> +x_0=4245000 +y_0=5295000 +a=6371229 +b=6371229 +units=m +no_defs '
> Also, if I try to reproject the file in EPSG:4326 with a gdalwarp
> (GDAL 3.1.3) command, it fails, because it does not read the source
> srs, but if I specify it using the -s_srs flag it works fine, example:
> |gdalwarp -of NetCDF -s_srs "+proj=stere +lat_0=90
> +lat_ts=59.99993768695209 +lon_0=-100 +x_0=4245000 +y_0=5295000
> +R=6371229 +units=m +no_defs" -t_srs EPSG:4326 input.nc output.nc|
> Is this a bug in gdal / proj, or a parameter in the projection
> definition that is not supported anymore ?
> Thanks
> LP
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20210728/438e1ca4/attachment-0001.html>
