[gdal-dev] Tons of errors in tests
Even Rouault even.rouault at spatialys.com
Wed Jun 2 08:38:23 PDT 2021
Javier,
CONTRIBUTING.md was missing the --with-python configure switch to build
the python bindings. Now fixed
So re-run ./configure --with-python && make -j8 -s , and also source
again ". scripts/setdevenv.sh" so that PYTHONPATH is set appropriately
You can check that everything is OK with:
python -c "from osgeo import gdal; print(gdal.__version__)"
Even
Le 02/06/2021 à 16:26, Javier Jimenez Shaw a écrit :
> Hello
> I am trying to build GDAL (this worked) and run the tests (tons of
> failures). Because it is over a clean clone of master, I think there
> is something wrong in my configuration. Maybe you can help me.
> OS: Ubuntu 20.04
> Python: 3.8.5
> $ apt list --installed | grep gdal
> gdal-bin/focal,now 3.0.4+dfsg-1build3 amd64 [installed]
> gdal-data/focal,focal,now 3.0.4+dfsg-1build3 all [installed,automatic]
> libgdal-dev/focal,now 3.0.4+dfsg-1build3 amd64 [installed]
> libgdal26/focal,now 3.0.4+dfsg-1build3 amd64 [installed,automatic]
> python3-gdal/focal,now 3.0.4+dfsg-1build3 amd64 [installed,automatic]
> Following the instructions in
> https://github.com/OSGeo/gdal/blob/master/CONTRIBUTING.md
> <https://github.com/OSGeo/gdal/blob/master/CONTRIBUTING.md>
> cd gdal
> ./configure
> make -j8 -s
> cd apps; make -s test_ogrsf; cd ..
> gdalinfo --version
> $ GDAL 3.4.0dev-6b8835c2b5, released 2021/06/02
> cd ../autotest
> pip install -r requirements.txt
> python -m pytest
> Test session starts (platform: linux, Python 3.8.5, pytest 4.6.9,
> pytest-sugar 0.9.4)
> rootdir: /home/jshaw/work/gdal/autotest, inifile: pytest.ini,
> testpaths: ogr, gcore, gdrivers, osr, alg, gnm, utilities, pyscripts
> plugins: sugar-0.9.4, env-0.6.2
> collecting ...
> ERROR collecting gcore/multidim.py
> gcore/multidim.py:106: in <module>
> E   AttributeError: module 'osgeo.gdal' has no attribute 'GRIORA_RMS'
> ERROR collecting alg/fillnodata.py
> /usr/lib/python3/dist-packages/pluggy/hooks.py:286: in __call__
>     return self._hookexec(self, self.get_hookimpls(), kwargs)
> /usr/lib/python3/dist-packages/pluggy/manager.py:92: in _hookexec
>     return self._inner_hookexec(hook, methods, kwargs)
> /usr/lib/python3/dist-packages/pluggy/manager.py:83: in <lambda>
>     self._inner_hookexec = lambda hook, methods, kwargs: hook.multicall(
> /usr/lib/python3/dist-packages/_pytest/python.py:234: in
> pytest_pycollect_makeitem
>     res = list(collector._genfunctions(name, obj))
> /usr/lib/python3/dist-packages/_pytest/python.py:410: in _genfunctions
>     self.ihook.pytest_generate_tests(metafunc=metafunc)
> /usr/lib/python3/dist-packages/_pytest/python.py:137: in
>     metafunc.parametrize(*marker.args, **marker.kwargs)
> /usr/lib/python3/dist-packages/_pytest/python.py:1015: in parametrize
>     ids = self._resolve_arg_ids(argnames, ids, parameters,
> item=self.definition)
> /usr/lib/python3/dist-packages/_pytest/python.py:1069: in _resolve_arg_ids
>     ids = idmaker(argnames, parameters, idfn, ids, self.config, item=item)
> /usr/lib/python3/dist-packages/_pytest/python.py:1221: in idmaker
>     ids = [
> /usr/lib/python3/dist-packages/_pytest/python.py:1222: in <listcomp>
>     _idvalset(valindex, parameterset, argnames, idfn, ids,
> config=config, item=item)
> /usr/lib/python3/dist-packages/_pytest/python.py:1210: in _idvalset
>     if ids is None or (idx >= len(ids) or ids[idx] is None):
> E   TypeError: 'dict_keys' object is not subscriptable
> ERROR collecting pyscripts/test_gdal_utils.py
> ImportError while importing test module
> '/home/jshaw/work/gdal/autotest/pyscripts/test_gdal_utils.py'.
> Hint: make sure your test modules/packages have valid Python names.
> Traceback:
> pyscripts/test_gdal_utils.py:37: in <module>
>     from osgeo_utils.auxiliary.extent_util import Extent
> E   ModuleNotFoundError: No module named 'osgeo_utils'
> ERROR collecting pyscripts/test_pct.py
> '/home/jshaw/work/gdal/autotest/pyscripts/test_pct.py'.
> Traceback:
> pyscripts/test_pct.py:37: in <module>
>     from osgeo_utils import gdalattachpct, rgb2pct
> ――――――――――――――――――――――――――――――――――――――――――――――――――――――――――――――― ERROR
> collecting pyscripts/gdal2tiles/test_add_alpha_band_to_string_vrt.py
> '/home/jshaw/work/gdal/autotest/pyscripts/gdal2tiles/test_add_alpha_band_to_string_vrt.py'.
> Traceback:
> pyscripts/gdal2tiles/test_add_alpha_band_to_string_vrt.py:36: in <module>
>     from osgeo_utils import gdal2tiles
> collecting
> pyscripts/gdal2tiles/test_add_gdal_warp_options_to_string.py
> '/home/jshaw/work/gdal/autotest/pyscripts/gdal2tiles/test_add_gdal_warp_options_to_string.py'.
> Traceback:
> pyscripts/gdal2tiles/test_add_gdal_warp_options_to_string.py:36: in
> <module>
> ERROR collecting pyscripts/gdal2tiles/test_nb_data_bands.py
> '/home/jshaw/work/gdal/autotest/pyscripts/gdal2tiles/test_nb_data_bands.py'.
> Traceback:
> pyscripts/gdal2tiles/test_nb_data_bands.py:35: in <module>
> ERROR collecting pyscripts/gdal2tiles/test_option_parser.py
> '/home/jshaw/work/gdal/autotest/pyscripts/gdal2tiles/test_option_parser.py'.
> Traceback:
> pyscripts/gdal2tiles/test_option_parser.py:37: in <module>
> ERROR collecting pyscripts/gdal2tiles/test_reproject_dataset.py
> '/home/jshaw/work/gdal/autotest/pyscripts/gdal2tiles/test_reproject_dataset.py'.
> Traceback:
> pyscripts/gdal2tiles/test_reproject_dataset.py:36: in <module>
> ERROR collecting pyscripts/gdal2tiles/test_setup_input_srs.py
> '/home/jshaw/work/gdal/autotest/pyscripts/gdal2tiles/test_setup_input_srs.py'.
> Traceback:
> pyscripts/gdal2tiles/test_setup_input_srs.py:34: in <module>
> ERROR collecting pyscripts/gdal2tiles/test_setup_no_data_value.py
> '/home/jshaw/work/gdal/autotest/pyscripts/gdal2tiles/test_setup_no_data_value.py'.
> Traceback:
> pyscripts/gdal2tiles/test_setup_no_data_value.py:34: in <module>
> collecting
> pyscripts/gdal2tiles/test_update_alpha_value_for_non_alpha_inputs.py
> '/home/jshaw/work/gdal/autotest/pyscripts/gdal2tiles/test_update_alpha_value_for_non_alpha_inputs.py'.
> Traceback:
> pyscripts/gdal2tiles/test_update_alpha_value_for_non_alpha_inputs.py:34:
> in <module>
> Interrupted: 12 errors during collection
> Results (5.85s):
> If I run a particular file, I get also a many errors (ommited here),
> and a core dump:
> python -m pytest gcore/tiff_read.py
>  gcore/tiff_read.py ⨯✓s    97% █████████▊
> Segmentation fault (core dumped)
> Is there anything basically wrong? Am I using the wrong gdal, not the
> one just compiled?
> Thanks
> .___ ._ ..._ .. . ._. .___ .. __ . _. . __..  ... .... ._ .__
> Entre dos pensamientos racionales
> hay infinitos pensamientos irracionales.
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20210602/c4408944/attachment-0001.html>
