[gdal-dev] Tons of errors in tests
Javier Jimenez Shaw j1 at jimenezshaw.com
Wed Jun 2 09:24:41 PDT 2021
Thanks Even and Andrew for your answers.
Andrew, somehow I had a workaround for the pytest-3 (that I absolutely
forgot), but thanks for the info.
Even, with the "--with-python" everything goes much better...
Now I can run tiff tests without any failure!
pytest gcore/tiff_*
However, if I run the full test suite, it fails collecting alg/fillnodata.py
(I work it around with "pytest --continue-on-collection-errors")
$ pytest
Test session starts (platform: linux, Python 3.8.5, pytest 4.6.9,
pytest-sugar 0.9.4)
rootdir: /home/jshaw/work/gdal/autotest, inifile: pytest.ini, testpaths:
ogr, gcore, gdrivers, osr, alg, gnm, utilities, pyscripts
plugins: sugar-0.9.4, env-0.6.2
collecting ...
ERROR collecting alg/fillnodata.py
/usr/lib/python3/dist-packages/pluggy/hooks.py:286: in __call__
    return self._hookexec(self, self.get_hookimpls(), kwargs)
/usr/lib/python3/dist-packages/pluggy/manager.py:92: in _hookexec
    return self._inner_hookexec(hook, methods, kwargs)
/usr/lib/python3/dist-packages/pluggy/manager.py:83: in <lambda>
    self._inner_hookexec = lambda hook, methods, kwargs: hook.multicall(
/usr/lib/python3/dist-packages/_pytest/python.py:234: in
pytest_pycollect_makeitem
    res = list(collector._genfunctions(name, obj))
/usr/lib/python3/dist-packages/_pytest/python.py:410: in _genfunctions
    self.ihook.pytest_generate_tests(metafunc=metafunc)
/usr/lib/python3/dist-packages/_pytest/python.py:137: in
    metafunc.parametrize(*marker.args, **marker.kwargs)
/usr/lib/python3/dist-packages/_pytest/python.py:1015: in parametrize
    ids = self._resolve_arg_ids(argnames, ids, parameters,
item=self.definition)
/usr/lib/python3/dist-packages/_pytest/python.py:1069: in _resolve_arg_ids
    ids = idmaker(argnames, parameters, idfn, ids, self.config, item=item)
/usr/lib/python3/dist-packages/_pytest/python.py:1221: in idmaker
    ids = [
/usr/lib/python3/dist-packages/_pytest/python.py:1222: in <listcomp>
    _idvalset(valindex, parameterset, argnames, idfn, ids, config=config,
item=item)
/usr/lib/python3/dist-packages/_pytest/python.py:1210: in _idvalset
    if ids is None or (idx >= len(ids) or ids[idx] is None):
E   TypeError: 'dict_keys' object is not subscriptable
Interrupted: 1 errors during collection
Results (5.42s):
Cheers
.___ ._ ..._ .. . ._.  .___ .. __ . _. . __..  ... .... ._ .__
Entre dos pensamientos racionales
hay infinitos pensamientos irracionales.
On Wed, 2 Jun 2021 at 17:38, Even Rouault <even.rouault at spatialys.com>
wrote:
> Javier,
> CONTRIBUTING.md was missing the --with-python configure switch to build
> the python bindings. Now fixed
> So re-run ./configure --with-python && make -j8 -s , and also source again
> ". scripts/setdevenv.sh" so that PYTHONPATH is set appropriately
> You can check that everything is OK with:
> python -c "from osgeo import gdal; print(gdal.__version__)"
> Even
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20210602/73f3b8bd/attachment.html>
