[gdal-dev] Edge Artifacts with GDAL Warp & Geolocation Arrays
Brendan Heberlein
bheberlein at wisc.edu
Fri Jun 11 12:30:26 PDT 2021
Hello all,
I have been using gdalwarp to georeference sensor data with geolocation arrays.
I have observed that GDAL assigns values to pixels that clearly fall outside the geolocation footprint, producing some funny artifacts at the image edges. For example, see the image here<https://pasteboard.co/K69DUni.png>.
(Sensor data over Google satellite basemap; red dots are geolocation points.)
Notice how the data values are 'extruded' from the edges.
This occurs with various interpolation methods (all the ones I tried), including nearest neighbor, average & bilinear. Why does this happen? How can I go about fixing this?
Ideally, any pixel in the output grid which lies more than 1 pixel width from any of the geolocation points (red dots) would be assigned to no-data.
My code is very straightforward, basically I open the raw sensor image & geolocation array (a.k.a. input geometry map or IGM) with GDAL & then assign geolocation metadata to the sensor image before warping:
# Geolocation domain metadata
geoloc_metadata = {
'SRS': WGS84_UTM16N.ExportToWkt(),
'X_BAND': '1',
'X_DATASET': str(igm_img_file),
'Y_BAND': '2',
'Y_DATASET': str(igm_img_file),
'PIXEL_OFFSET': '0',
'LINE_OFFSET': '0',
'PIXEL_STEP': '1',
'LINE_STEP': '1',
# Set geolocation domain metadata on dataset to be warped
dn_img_ds.SetMetadata(geoloc_metadata, 'GEOLOCATION')
x_min, y_min = igm[:2].min(axis=(1,2))
x_max, y_max = igm[:2].max(axis=(1,2))
# warp_options = gdal.WarpOptions(warpMemoryLimit=)
warped_ds = gdal.Warp(f'/warped.tif', dn_img_ds,
outputBounds=(x_min, y_min, x_max, y_max),
xRes=1.0,
yRes=1.0,
resampleAlg='near',
dstSRS=WGS84_UTM16N,
srcNodata=None,
dstNodata=-9999,
multithread=True,
targetAlignedPixels=True,
outputType=get_gdal_dtype(np.int16),
geoloc=True)
Any insight would be much appreciated. Cheers!
— Brendan Heberlein
Research Intern, BS
Townsend Lab
University of Wisconsin - Madison
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20210611/9c552243/attachment.html>
