[gdal-dev] Edge Artifacts with GDAL Warp & Geolocation Arrays
Even Rouault
even.rouault at spatialys.com
Fri Jun 11 12:49:43 PDT 2021
I believe https://github.com/OSGeo/gdal/pull/3964 should improve this
Even
Le 11/06/2021 à 21:30, Brendan Heberlein via gdal-dev a écrit :
> Hello all,
> I have been using |gdalwarp| to georeference sensor data with
> geolocation arrays.
> I have observed that GDAL assigns values to pixels that clearly fall
> outside the geolocation footprint, producing some funny artifacts at
> the image edges. For example, see the image here
> <https://pasteboard.co/K69DUni.png>.
> (Sensor data over Google satellite basemap; red dots are geolocation
> points.)
> Notice how the data values are 'extruded' from the edges.
> This occurs with various interpolation methods (all the ones I tried),
> including nearest neighbor, average & bilinear. Why does this happen?
> How can I go about fixing this?
> Ideally, any pixel in the output grid which lies more than 1 pixel
> width from any of the geolocation points (red dots) would be assigned
> to no-data.
> My code is very straightforward, basically I open the raw sensor image
> & geolocation array (a.k.a. input geometry map or IGM) with GDAL &
> then assign geolocation metadata to the sensor image before warping:
> # Geolocation domain metadata
> geoloc_metadata = {
> 'SRS': WGS84_UTM16N.ExportToWkt(),
> 'X_BAND': '1',
> 'X_DATASET': str(igm_img_file),
> 'Y_BAND': '2',
> 'Y_DATASET': str(igm_img_file),
> 'PIXEL_OFFSET': '0',
> 'LINE_OFFSET': '0',
> 'PIXEL_STEP': '1',
> 'LINE_STEP': '1',
> # Set geolocation domain metadata on dataset to be warped
> dn_img_ds.SetMetadata(geoloc_metadata, 'GEOLOCATION')
> x_min, y_min = igm[:2].min(axis=(1,2))
> x_max, y_max = igm[:2].max(axis=(1,2))
> # warp_options = gdal.WarpOptions(warpMemoryLimit=)
> warped_ds = gdal.Warp(f'/warped.tif', dn_img_ds,
> outputBounds=(x_min, y_min, x_max, y_max),
> xRes=1.0,
> yRes=1.0,
> resampleAlg='near',
> dstSRS=WGS84_UTM16N,
> srcNodata=None,
> dstNodata=-9999,
> multithread=True,
> targetAlignedPixels=True,
> outputType=get_gdal_dtype(np.int16),
> geoloc=True)
> Any insight would be much appreciated. Cheers!
> — Brendan Heberlein
> Research Intern, BS
> Townsend Lab
> University of Wisconsin - Madison
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20210611/c6bdf7d2/attachment-0001.html>
