[gdal-dev] OCI vector driver - could support be added for Oracle Wallet? (simple change?)
Even Rouault
even.rouault at spatialys.com
Mon Jun 14 08:23:34 PDT 2021
Steve,
I believe https://github.com/OSGeo/gdal/pull/3784 has fixed that (in the
master branch)
Even
Le 14/06/2021 à 17:18, Steve Pritchard a écrit :
> Oracle Wallet provides secure storage for usernames and passwords on
> client devices. We use this to avoid having usernames and passwords in
> scripts, etc. For details see "Using The Secure External Password
> Store (Doc ID 340559.1)" on the Oracle Support website.
> I have tried using Oracle Wallet with ogrinfo and the OCI driver, e.g.:
> ogrinfo OCI:/@db_name:table_name
> however I always get:
> ERROR 1: ORA-01017: invalid username/password; logon denied
> in <unnamed>
> in <unnamed>
> FAILURE:
> Unable to open datasource `OCI:..' with the following drivers.
> I have tried this both with the bundled Oracle Instant Client and with
> the latest Instant Client from the Oracle website. I've also tested
> Oracle Wallet with other open source software (e.g. Perl DBI), and
> that works fine.
> Having looked at the source code for ogrocisession.cpp, it looks as
> though a simple change might be sufficient to make this work...
> I think that the reason it doesn't work is because the "eCred"
> parameter needs to be OCI_CRED_EXT for Oracle Wallet. But eCred is set
> to OCI_CRED_RDBMS, except where OS authentication is being used.
> So if pszUseridIn = "" and pszPasswordIn = "", can eCred be set to
> OCI_CRED_EXT?
> (Notes on using Oracle Wallet with Oracle OCI can be found in the
> answer tothis stackoverflow question
> <https://stackoverflow.com/questions/21762885/using-oracle-wallet-authentication-from-oci>)
> Steve
> Steve Pritchard
> Database Developer
> British Trust for Ornithology, The Nunnery, Thetford, Norfolk IP24
> 2PU, UK
> Tel: +44 (0)1842 750050, fax: +44 (0)1842 750030
> Registered Charity No 216652 (England & Wales) No SC039193 (Scotland)
> Company Limited by Guarantee No 357284 (England & Wales)
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20210614/832938dc/attachment.html>
