[gdal-dev] OCI vector driver - could support be added for Oracle Wallet? (simple change?)
Steve Pritchard
steve.pritchard at bto.org
Wed Jun 23 06:28:09 PDT 2021
Many thanks Even.
This fix doesn't seem to be in a release yet, but I've managed to build
GDAL from master, and this works correctly with Oracle Wallet.
Steve
Steve Pritchard
Database Developer
British Trust for Ornithology, The Nunnery, Thetford, Norfolk IP24 2PU, UK
Tel: +44 (0)1842 750050, fax: +44 (0)1842 750030
Registered Charity No 216652 (England & Wales) No SC039193 (Scotland)
Company Limited by Guarantee No 357284 (England & Wales)
> Date: Mon, 14 Jun 2021 17:23:34 +0200
> From: Even Rouault <even.rouault at spatialys.com>
> To: gdal-dev at lists.osgeo.org
> Subject: Re: [gdal-dev] OCI vector driver - could support be added for
> Message-ID: <402aeda2-9b94-c1d8-0788-ac7187bacffe at spatialys.com>
> Content-Type: text/plain; charset="utf-8"; Format="flowed"
> Steve,
> I believe https://github.com/OSGeo/gdal/pull/3784 has fixed that (in the
> master branch)
> Even
> Le 14/06/2021 ? 17:18, Steve Pritchard a ?crit?:
> > Oracle Wallet provides secure storage for usernames and passwords on
> > client devices. We use this to avoid having usernames and passwords in
> > scripts, etc. For details see "Using The Secure External Password
> > Store (Doc ID 340559.1)" on the Oracle Support website.
> > I have tried using Oracle Wallet with ogrinfo and the OCI driver, e.g.:
> > ogrinfo OCI:/@db_name:table_name
> > however I always get:
> > ERROR 1: ORA-01017: invalid username/password; logon denied
> > ?in <unnamed>
> > ?in <unnamed>
> > FAILURE:
> > Unable to open datasource `OCI:..' with the following drivers.
> > I have tried this both with the bundled Oracle Instant Client and with
> > the latest Instant Client from the Oracle website. I've also tested
> > Oracle Wallet with other open source software (e.g. Perl DBI), and
> > that works fine.
> > Having looked at the source?code for?ogrocisession.cpp, it looks as
> > though a simple change might be sufficient to make this work...
> > I think that the reason it doesn't work is because the "eCred"
> > parameter needs to be OCI_CRED_EXT for Oracle Wallet. But eCred is set
> > to?OCI_CRED_RDBMS, except where OS authentication is being used.
> > So if?pszUseridIn = "" and?pszPasswordIn = "", can eCred be set to
> > OCI_CRED_EXT?
> > (Notes on using Oracle Wallet with Oracle OCI can be found in the
> > answer tothis stackoverflow question
> https://stackoverflow.com/questions/21762885/using-oracle-wallet-authentication-from-oci
> > Steve
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20210623/fbdd8a11/attachment.html>
