[gdal-dev] TypeError Wrong number or type of arguments for overloaded function 'CoordinateTransformation_TransformPoint'.
Paul Harwood
runette at gmail.com
Wed Jun 16 05:11:10 PDT 2021
actually you probably also need to add:
conda install -c conda-forge gdal
since you are using the OSGeo python package and I don't you get that with
the Fiona conda package
On Wed, 16 Jun 2021 at 12:57, Paul Harwood <runette at gmail.com> wrote:
> As per my email :
> - I would probably start again from scratch - i.e.
> conda create --name test
> conda activate test
> conda install -c conda-forge fiona
> conda install -c conda-forge pyproj
> and see what you get.
> If you are working in conda - you should NEVER have to tamper with
> proj.dll or proj.db files.
> On Wed, 16 Jun 2021 at 11:49, zerovirus123 <briansia93 at gmail.com> wrote:
>> Hi,
>> Based on the above suggestions? Should I just rebuild a fresh
>> environment? Or tamper with proj.dll files?
>> Thanks.
>> Sent from: http://osgeo-org.1560.x6.nabble.com/GDAL-Dev-f3742093.html
>> gdal-dev mailing list
>> gdal-dev at lists.osgeo.org
>> https://lists.osgeo.org/mailman/listinfo/gdal-dev
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20210616/e6217543/attachment.html>
