[gdal-dev] TypeError Wrong number or type of arguments for overloaded function 'CoordinateTransformation_TransformPoint'.
Paul Harwood
runette at gmail.com
Wed Jun 16 04:57:57 PDT 2021
As per my email :
- I would probably start again from scratch - i.e.
conda create --name test
conda activate test
conda install -c conda-forge fiona
conda install -c conda-forge pyproj
and see what you get.
If you are working in conda - you should NEVER have to tamper with proj.dll
or proj.db files.
On Wed, 16 Jun 2021 at 11:49, zerovirus123 <briansia93 at gmail.com> wrote:
> Hi,
> Based on the above suggestions? Should I just rebuild a fresh
> environment? Or tamper with proj.dll files?
> Thanks.
> Sent from: http://osgeo-org.1560.x6.nabble.com/GDAL-Dev-f3742093.html
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20210616/5112f1aa/attachment.html>
