[gdal-dev] gdal Vertical Datum/ Reference System
fiat lux fiatlux113 at gmail.com
Wed Jun 16 08:02:42 PDT 2021
Thanks very much. your tip  was  much helpful
Even Rouault <even.rouault at spatialys.com> escreveu no dia quarta,
16/06/2021 à(s) 14:19:
> Fiat,
> You could start by setting the environment variable / configuration option
> GTIFF_REPORT_COMPD_CS to YES (see
> https://gdal.org/drivers/raster/gtiff.html#configuration-options), that
> will make the GeoTIFF driver report a Compound CRS if the GeoTIFF keys
> contain information on the vertical CRS/datum.
> If that doesn't work, then you'll have to connect with the data producer
> and ask him...
> Even
> Le 16/06/2021 à 15:15, fiat lux a écrit :
> I need help with identifying vertical datum on raster for a project that I
> am working on. When I run gdalinfo raster.tif, I can identify the
> horizontal reference system as given by the EPSG:XXXX. However, I am
> struggling identifying the vertical reference system; which is a
> prerequisite for transforming vertical datum using gdal.
> Thanks for the help
> Fiat
> gdal-dev mailing listgdal-dev at lists.osgeo.orghttps://lists.osgeo.org/mailman/listinfo/gdal-dev
> -- http://www.spatialys.com
> My software is free, but my time generally not.
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20210616/9e3bf0b4/attachment.html>
