[gdal-dev] gdal Vertical Datum/ Reference System
Even Rouault even.rouault at spatialys.com
Wed Jun 16 06:19:56 PDT 2021
Fiat,
You could start by setting the environment variable / configuration
option GTIFF_REPORT_COMPD_CS to YES (see
https://gdal.org/drivers/raster/gtiff.html#configuration-options), that
will make the GeoTIFF driver report a Compound CRS if the GeoTIFF keys
contain information on the vertical CRS/datum.
If that doesn't work, then you'll have to connect with the data producer
and ask him...
Even
Le 16/06/2021 à 15:15, fiat lux a écrit :
> I need help with identifying vertical datum on raster for a project
> that I am working on. When I run gdalinfo raster.tif, I can identify
> the horizontal reference system as given by the EPSG:XXXX. However, I
> am struggling identifying the vertical reference system; which is a
> prerequisite for transforming vertical datum using gdal.
> Thanks for the help
> Fiat
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20210616/2ea4c74d/attachment.html>
