[gdal-dev] Polygon operations
Even Rouault even.rouault at spatialys.com
Sat Jun 19 14:16:41 PDT 2021
The polygon of a cutline is reprojected into the coordinate system of
the source image, so densification of its contour might have an effect
indeed.
Le 19/06/2021 à 22:27, Metabase Account a écrit :
> I might be thinking of this incorrectly, but if they're done in 2D
> without any spatial consideration, inserting additional vertices in
> between shouldn't have an effect on behavior right? However it does
> seem to have an effect when using operations such as warp with the
> polygon as the cutline.
http://www.spatialys.com
