[gdal-dev] I couldn't use OGRCreateCoordinateTransformation
Ahmet Temiz ahmettemiz88 at gmail.com
Sun Jun 20 01:28:26 PDT 2021
Thank you,
I am reading a shape file with line geometry in epsg:3857 projection.
.I create buffer from lines (polyCollect)
.union  them (unionCascaded)
. then convert it to multipolygon (poOGRMultiPolygon)
. then transform is necessary for each polygon in poPolygon from epsg:3857
to epsg:4326
  Here is the code:
    OGRGeometry * unionCascaded = polyCollect->UnionCascaded();
    OGRMultiPolygon * poOGRMultiPolygon= ( OGRMultiPolygon * )
unionCascaded;
    int NumberOfGeometries= poOGRMultiPolygon->getNumGeometries();
    OGRSpatialReference source;
    OGRSpatialReference dest;
    source.SetWellKnownGeogCS( "EPSG:3857" );
    dest.SetWellKnownGeogCS( "EPSG:4326" );
    OGRCoordinateTransformation* ct =
OGRCreateCoordinateTransformation(&source, &dest);
    for (int j=0; j< NumberOfGeometries ;j++    ){
        OGRGeometry * polyGeometry = poOGRMultiPolygon -> getGeometryRef(j);
        OGRPolygon *poPolygon= ( OGRPolygon *) polyGeometry;
        OGRErr err=poPolygon->transform(ct) ;
On Sun, Jun 20, 2021 at 11:02 AM Brad Hards <bradh at frogmouth.net> wrote:
> What is the `polyGeometry`?
> Can you try to generate a compilable, minimal, self-contained example that
> demonstrates the problem?
> Brad
> *From:* gdal-dev <gdal-dev-bounces at lists.osgeo.org> *On Behalf Of *Ahmet
> Temiz
> *Sent:* Sunday, 20 June 2021 5:56 PM
> *To:* gdal-dev <gdal-dev at lists.osgeo.org>
> *Subject:* [gdal-dev] I couldn't use OGRCreateCoordinateTransformation
> Hi,
> OGRErr err=poPolygon->transform(ct) ;  // it generates this error.
> ERROR 6: No translation for an empty SRS to PROJ.4 format is known.
> I think, this occurs, because I could not assign any SRS value to polygon
> How can I solve this problem?
> regards
> Ahmet Temiz
> Jeoloji Müh.
> Afet ve Acil Durum Yönetimi Başkanlığı
> Deprem  Dairesi Başkanlığı
> ________________________
> Ahmet Temiz
> Geological Eng.
> Disaster and Emergency Management
> of Presidency
Ahmet Temiz
Jeoloji Müh.
Ahmet Temiz
Geological Eng.
of Presidency
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20210620/2a80c4e8/attachment.html>
