[gdal-dev] I couldn't use OGRCreateCoordinateTransformation
Brad Hards
bradh at frogmouth.net
Sun Jun 20 03:01:02 PDT 2021
Does that code compile for you? What are you expecting this line to do:
OGRLineString *poLine = (OGRLineString *) poGeometry;
Where is poGeometry even defined?
Brad
Sent: Sunday, 20 June 2021 6:30 PM
To: Brad Hards <bradh at frogmouth.net>
Subject: Re: [gdal-dev] I couldn't use OGRCreateCoordinateTransformation
Here is the full code
regards
On Sun, Jun 20, 2021 at 11:02 AM Brad Hards <bradh at frogmouth.net <mailto:bradh at frogmouth.net> > wrote:
What is the `polyGeometry`?
Can you try to generate a compilable, minimal, self-contained example that demonstrates the problem?
Brad
From: gdal-dev <gdal-dev-bounces at lists.osgeo.org <mailto:gdal-dev-bounces at lists.osgeo.org> > On Behalf Of Ahmet Temiz
Sent: Sunday, 20 June 2021 5:56 PM
To: gdal-dev <gdal-dev at lists.osgeo.org <mailto:gdal-dev at lists.osgeo.org> >
Subject: [gdal-dev] I couldn't use OGRCreateCoordinateTransformation
source.SetWellKnownGeogCS( "EPSG:3857" );
dest.SetWellKnownGeogCS( "EPSG:4326" );
OGRCoordinateTransformation* ct = OGRCreateCoordinateTransformation(&source, &dest);
OGRPolygon *poPolygon= ( OGRPolygon *) polyGeometry;
OGRErr err=poPolygon->transform(ct) ; // it generates this error.
ERROR 6: No translation for an empty SRS to PROJ.4 format is known.
I think, this occurs, because I could not assign any SRS value to polygon
How can I solve this problem?
regards
Ahmet Temiz
Jeoloji Müh.
Afet ve Acil Durum Yönetimi Başkanlığı
Deprem Dairesi Başkanlığı
________________________
Ahmet Temiz
Geological Eng.
Disaster and Emergency Management
of Presidency
Ahmet Temiz
Jeoloji Müh.
Ahmet Temiz
Geological Eng.
of Presidency
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20210620/4ee1a80a/attachment.html>
