[gdal-dev] Elasticsearch, rename index names
Even Rouault
even.rouault at spatialys.com
Wed Jun 23 14:44:43 PDT 2021
Jens,
You could use the GDALVectorTranslate() API (the library version of
ogr2ogr) with the -nln option.
See
https://gdal.org/api/gdal_utils.html#gdal__utils_8h_1aa176ae667bc857ab9c6016dbe62166eb
Even
Le 23/06/2021 à 23:37, Jens Søe Christiansen a écrit :
> Hi
> Yet another challenge regarding the awesome CopyDataSource :-)
> I'm trying to read a WFS service and write it to Elasticsearch. This
> is almost working but my problem is the name of the layers in the
> source. They come with a prefix (gdk60:) and : are not valid in an
> index name in Elasticsearch!
> If I set the index name nothing is working since the source contains
> multiple layers so is there any way to add a mapping of layer names to
> index names like the field mapper?
> Best regards
> Jens Christiansen
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20210623/2c9771a7/attachment.html>
