[gdal-dev] GDAL 2.1.4, released 2017/06/23 win32 mingw binaries
Francesco Lazzarotto francesco.lazzarotto at inaf.it
Fri Jun 25 02:12:26 PDT 2021
Hello,
I compiled a GDAL 2.1.4 build for MS win 32bit using
i686-w64-mingw32-gcc / g++ compiler
tested to work on win32 and win64.
If someone is interested I share a link to the binary package
gdal-2-i686-w64-mingw32.tgz
https://drive.google.com/file/d/14j4NdFnH-Q_SxjXpw6D0K1ToYoP-LrMo/view?usp=sharing
<https://drive.google.com/file/d/14j4NdFnH-Q_SxjXpw6D0K1ToYoP-LrMo/view?usp=sharing>
Best Regards,
Francesco Lazzarotto.
gdalinfo.exe --formats
Supported Formats:
   VRT -raster- (rw+v): Virtual Raster
   GTiff -raster- (rw+vs): GeoTIFF
   NITF -raster- (rw+vs): National Imagery Transmission Format
   RPFTOC -raster- (rovs): Raster Product Format TOC format
   ECRGTOC -raster- (rovs): ECRG TOC format
   HFA -raster- (rw+v): Erdas Imagine Images (.img)
   SAR_CEOS -raster- (rov): CEOS SAR Image
   CEOS -raster- (rov): CEOS Image
   JAXAPALSAR -raster- (rov): JAXA PALSAR Product Reader (Level 1.1/1.5)
   GFF -raster- (rov): Ground-based SAR Applications Testbed File Format
(.gff)
   ELAS -raster- (rw+v): ELAS
   AIG -raster- (rov): Arc/Info Binary Grid
   AAIGrid -raster- (rwv): Arc/Info ASCII Grid
   GRASSASCIIGrid -raster- (rov): GRASS ASCII Grid
   SDTS -raster- (rov): SDTS Raster
   DTED -raster- (rwv): DTED Elevation Raster
   PNG -raster- (rwv): Portable Network Graphics
   JPEG -raster- (rwv): JPEG JFIF
   MEM -raster- (rw+): In Memory Raster
   JDEM -raster- (rov): Japanese DEM (.mem)
   GIF -raster- (rwv): Graphics Interchange Format (.gif)
   BIGGIF -raster- (rov): Graphics Interchange Format (.gif)
   ESAT -raster- (rov): Envisat Image Format
   BSB -raster- (rov): Maptech BSB Nautical Charts
   XPM -raster- (rwv): X11 PixMap Format
   BMP -raster- (rw+v): MS Windows Device Independent Bitmap
   DIMAP -raster- (rov): SPOT DIMAP
   AirSAR -raster- (rov): AirSAR Polarimetric Image
   RS2 -raster- (ros): RadarSat 2 XML Product
   SAFE -raster- (rov): Sentinel-1 SAR SAFE Product
   PCIDSK -raster,vector- (rw+v): PCIDSK Database File
   PCRaster -raster- (rw+): PCRaster Raster File
   ILWIS -raster- (rw+v): ILWIS Raster Map
   SGI -raster- (rw+): SGI Image File Format 1.0
   SRTMHGT -raster- (rwv): SRTMHGT File Format
   Leveller -raster- (rw+): Leveller heightfield
   Terragen -raster- (rw+): Terragen heightfield
   ISIS3 -raster- (rov): USGS Astrogeology ISIS cube (Version 3)
   ISIS2 -raster- (rw+v): USGS Astrogeology ISIS cube (Version 2)
   PDS -raster- (rov): NASA Planetary Data System
   VICAR -raster- (rov): MIPL VICAR file
   TIL -raster- (rov): EarthWatch .TIL
   ERS -raster- (rw+v): ERMapper .ers Labelled
   L1B -raster- (rovs): NOAA Polar Orbiter Level 1b Data Set
   FIT -raster- (rwv): FIT Image
   GRIB -raster- (rov): GRIdded Binary (.grb)
   RMF -raster- (rw+v): Raster Matrix Format
   WCS -raster- (rovs): OGC Web Coverage Service
   WMS -raster- (rwvs): OGC Web Map Service
   MSGN -raster- (ro): EUMETSAT Archive native (.nat)
   RST -raster- (rw+v): Idrisi Raster A.1
   INGR -raster- (rw+v): Intergraph Raster
   GSAG -raster- (rwv): Golden Software ASCII Grid (.grd)
   GSBG -raster- (rw+v): Golden Software Binary Grid (.grd)
   GS7BG -raster- (rw+v): Golden Software 7 Binary Grid (.grd)
   COSAR -raster- (rov): COSAR Annotated Binary Matrix (TerraSAR-X)
   TSX -raster- (rov): TerraSAR-X Product
   COASP -raster- (ro): DRDC COASP SAR Processor Raster
   R -raster- (rwv): R Object Data Store
   MAP -raster- (rov): OziExplorer .MAP
   KMLSUPEROVERLAY -raster- (rwv): Kml Super Overlay
   PDF -raster,vector- (w+): Geospatial PDF
   Rasterlite -raster- (rws): Rasterlite
   MBTiles -raster- (rw+v): MBTiles
   PLMOSAIC -raster- (ro): Planet Labs Mosaics API
   CALS -raster- (rw): CALS (Type 1)
   WMTS -raster- (rwv): OGC Web Mab Tile Service
   SENTINEL2 -raster- (rovs): Sentinel 2
   MRF -raster- (rw+v): Meta Raster Format
   PNM -raster- (rw+v): Portable Pixmap Format (netpbm)
   DOQ1 -raster- (rov): USGS DOQ (Old Style)
   DOQ2 -raster- (rov): USGS DOQ (New Style)
   GenBin -raster- (rov): Generic Binary (.hdr Labelled)
   PAux -raster- (rw+): PCI .aux Labelled
   MFF -raster- (rw+v): Vexcel MFF Raster
   MFF2 -raster- (rw+): Vexcel MFF2 (HKV) Raster
   FujiBAS -raster- (ro): Fuji BAS Scanner Image
   GSC -raster- (rov): GSC Geogrid
   FAST -raster- (rov): EOSAT FAST Format
   BT -raster- (rw+v): VTP .bt (Binary Terrain) 1.3 Format
   LAN -raster- (rw+v): Erdas .LAN/.GIS
   CPG -raster- (ro): Convair PolGASP
   IDA -raster- (rw+v): Image Data and Analysis
   NDF -raster- (rov): NLAPS Data Format
   EIR -raster- (rov): Erdas Imagine Raw
   DIPEx -raster- (rov): DIPEx
   LCP -raster- (rwv): FARSITE v.4 Landscape File (.lcp)
   GTX -raster- (rw+v): NOAA Vertical Datum .GTX
   LOSLAS -raster- (rov): NADCON .los/.las Datum Grid Shift
   NTv2 -raster- (rw+vs): NTv2 Datum Grid Shift
   CTable2 -raster- (rw+v): CTable2 Datum Grid Shift
   ACE2 -raster- (rov): ACE2
   SNODAS -raster- (rov): Snow Data Assimilation System
   KRO -raster- (rw+v): KOLOR Raw
   ROI_PAC -raster- (rw+v): ROI_PAC raster
   ENVI -raster- (rw+v): ENVI .hdr Labelled
   EHdr -raster- (rw+v): ESRI .hdr Labelled
   ISCE -raster- (rw+v): ISCE raster
   ARG -raster- (rwv): Azavea Raster Grid format
   RIK -raster- (rov): Swedish Grid RIK (.rik)
   USGSDEM -raster- (rwv): USGS Optional ASCII DEM (and CDED)
   GXF -raster- (ro): GeoSoft Grid Exchange Format
   NWT_GRD -raster- (rov): Northwood Numeric Grid Format .grd/.tab
   NWT_GRC -raster- (rov): Northwood Classified Grid Format .grc/.tab
   ADRG -raster- (rw+vs): ARC Digitized Raster Graphics
   SRP -raster- (rovs): Standard Raster Product (ASRP/USRP)
   BLX -raster- (rwv): Magellan topo (.blx)
   SAGA -raster- (rw+v): SAGA GIS Binary Grid (.sdat)
   XYZ -raster- (rwv): ASCII Gridded XYZ
   HF2 -raster- (rwv): HF2/HFZ heightfield raster
   OZI -raster- (rov): OziExplorer Image File
   CTG -raster- (rov): USGS LULC Composite Theme Grid
   E00GRID -raster- (rov): Arc/Info Export E00 GRID
   ZMap -raster- (rwv): ZMap Plus Grid
   NGSGEOID -raster- (rov): NOAA NGS Geoid Height Grids
   IRIS -raster- (rov): IRIS data (.PPI, .CAPPi etc)
   GPKG -raster,vector- (rw+vs): GeoPackage
   PLSCENES -raster,vector- (ro): Planet Labs Scenes API
   HTTP -raster,vector- (ro): HTTP Fetching Wrapper
