[gdal-dev] gdaldem aspect is grid-oriented
Michael Sumner mdsumner at gmail.com
Mon Jun 28 08:14:48 PDT 2021
True, we don't care where the needle points - we need polar north, it's
entirely dependent on longitude, and in our usual case, stere centred on
south pole, a simple special case.
Cheers, Mike
On Tue, 29 Jun 2021, 01:06 Andrew C Aitchison, <andrew at aitchison.me.uk>
wrote:
> On Fri, 25 Jun 2021, Michael Sumner wrote:
> > Hello, we're using `gdaldem aspect` on polar grid products and we need to
> > convert the grid-oriented directions to compass oriented ones,
> > location-specific directions, where "compass north" is dependent on
> > longitude.
> I am curious; in the terminology of the British Ordnance Survey maps,
> you are converting from "Grid North" but are you trying
> to convert to "True North" or to "Magnetic North" ?
> Andrew C. Aitchison                                     Kendal, UK
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20210629/52c787df/attachment.html>
