[gdal-dev] gdaladdo bigtiff err but --config BIGTIFF was used
thomas bonfort thomas.bonfort at gmail.com
Mon Jun 28 10:28:01 PDT 2021
cogger v0.0.5 now supports .ovr external overviews. It will automatically
set the output cog to bigtiff if required, so your use-case should now be
covered.
Thomas
Le lun. 14 juin 2021 à 22:12, <Matt.Wilkie at yukon.ca> a écrit :
> > You can create external overviews with the -ro switch
> Yeah, I have those. I was trying to create internal ones instead in order
> to use cogger ;-)
> (And behind all of this, a weeping and wailing and gnashing of teeth at
> the upstream person or persons who decided that creating jpegs and throwing
> away the originals was "good enough". Oh well, my history is littered with
> bad calls too.)
> Matt
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20210628/dfc229c7/attachment.html>
