[gdal-dev] GDAL SVG to BMP conversion
jratike80
jukka.rahkonen at maanmittauslaitos.fi
Tue Mar 2 14:31:58 PST 2021
You can test it with any SVG file
ogrinfo matplotlib.svg --debug on
SVG: matplotlib.svg seems to be a SVG file, but not a Cloudmade vector one.
I recommend to use some other tools.
-Jukka Rahkonen-
Shaw, Theodore wrote
> I'm attempting to convert SVG files output by Gdspy to large BMPs,
> approximately 50,000 x 50,000 pixels. This documentation page
> https://gdal.org/drivers/vector/svg.html looks like it says that GDAL
> only supports SVG files that are the output of Cloudmade Vector Stream
> Server. Am I understanding correctly that I won't be able to use GDAL
> for this task?
> Thank you very much.
> gdal-dev mailing list
> gdal-dev at .osgeo
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
Sent from: http://osgeo-org.1560.x6.nabble.com/GDAL-Dev-f3742093.html
