[gdal-dev] Motion: remove and deprecate a few drivers
Even Rouault even.rouault at spatialys.com
Wed Mar 3 11:35:51 PST 2021
Is the GSAG format really used ?
Which one(s) are proposed by default as output of current Surfer versions ?
Can't Surfer export to other formats already handled by GDAL ?
Le 03/03/2021 à 20:02, Joaquim Manuel Freire Luís a écrit :
> Even,
> May you reconsider the Golden Software drivers --- GS7BG, GSAG, GSBG --- ?
> GMT can read/write GSBG, but specially GS7BG, besides Surfer, GDAL is the only one that I know that is able to read this format. Maybe not in this list but there are still many people who use Golden software grid formats.
> Joaquim
> -----Original Message-----
> From: gdal-dev <gdal-dev-bounces at lists.osgeo.org> On Behalf Of Even Rouault
> Sent: Wednesday, March 3, 2021 6:49 PM
> To: gdal-dev at lists.osgeo.org
> Subject: [gdal-dev] Motion: remove and deprecate a few drivers
> Hi,
> Following the discussions of past weeks, I motion to:
> - remove the vector drivers BNA, AeronavFAA, HTF, OpenAir, SEGUKOOA, SEGY, SUA, XPlane and raster drivers BPG, E00GRID, EPSILON, IGNFHeightASCIIGrid, NTv1. They have all been authored by myself and I'm not aware of them having been much used or being still in use.
> Implemented in https://github.com/OSGeo/gdal/pull/3373. They (driver code, doc and tests) have been moved to the https://github.com/OSGeo/gdal-extra-drivers
> - deprecate the raster drivers DODS, FIT, GS7BG, GSAG, GSBG, JDEM, JPEG2000, JPEGLS, MG4LIDAR, GMT, DOQ1, DOQ2, FUJIBAS, IDA, LAN, MFF, NDF, SDTS, SGI, XPM, ZMAP and vector driver ARCGEN, ArcObjects, CLOUDANT, COUCHDB, DB2, DODS, FME, GEOMEDIA, GTM, INGRES, MONGODB, REC, SDTDS, TIGER, WALK. They will now be disabled at runtime by default, unless the GDAL_ENABLE_DEPRECATED_DRIVER_{drivername}
> configuration option is set to YES, and will be removed in GDAL 3.5.
> Implemented in https://github.com/OSGeo/gdal/pull/3505
> Starting with my +1
> Even
> http://www.spatialys.com
> gdal-dev mailing list
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
